front end alignment #2648513
04/24/19 03:25 PM
04/24/19 03:25 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
Just got through rebuilding the front end of the dart and doing the home alignment on it so it will be good enough to get it to an alignment shop. Doing a bunch of reading on this and read that these cars like+1 degree of caster, but no matter how much adjustment I do on the upper control arm, I cant get the lower ball joint to sit ahead of the upper ball joint, so how can you get positive caster with stock bushings?
Re: front end alignment [Re: mopower440] #2648515
04/24/19 03:30 PM
04/24/19 03:30 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you have the upper arms on correct side of car, and the lower strut bushings cranked tight into K frame, you should be able to get a decent adjustment. Might take some creative adjustment of the cams in upper arms I suppose.
Re: front end alignment [Re: mopower440] #2648519
04/24/19 03:37 PM
04/24/19 03:37 PM
Kirkland, Washington
Pacnorthcuda Offline
You don’t want negative caster....you want positive, and it’s not likely you can get it with a stock set up.
BUT......
You don’t need to concern yourself with caster just for a drive to the alignment. Just make the wheels reasonably vertical, that’s camber.
Also make a reasonable toe setting by setting the front edge distance equal to the rear edge.
I would highly recommend YOU set the right height first, to what you want, most shops don’t adjust this (they should) and it does affect the alignment, so it’s done first,
Re: front end alignment [Re: Pacnorthcuda] #2648536
04/24/19 04:22 PM
04/24/19 04:22 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Exactly as Pacnorth suggested, say no to negative caster. The problem is the stock components will often not have enough adjustment in them to get a decent amount of positive.
Resolve this before your alignment, either buy replacing the upper arms or some other method. Offset upper bushings are the cheapest option but a bushing that is paper thin on one side was never meant to be but it works in a pinch.
Re: front end alignment [Re: Magnum] #2648554
04/24/19 05:12 PM
04/24/19 05:12 PM
A727Tflite Offline
A727Tflite  Offline
Is the car pretty level front to back or is it a&& high in the back or toad low in the front ?
Re: front end alignment [Re: A727Tflite] #2648556
04/24/19 05:18 PM
04/24/19 05:18 PM
middle Tennessee
middle Tennessee
sorry guys, I meant positive caster, not negative..i went back and edited the post and changed it to say positive..
Re: front end alignment [Re: Magnum] #2648558
04/24/19 05:30 PM
04/24/19 05:30 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I run the Moog offset bushings and run 4*caster, -0.8* camber and 1/8" toe. I tell the alignment shop to use 2005 Mustang specs and they get it as close as they can. I've got adjustable strut rods
I'll see how the offsets hold up long term, but there is a good 1/4" of bushing material on the thin side. They are polyurethane and I'm not sure I would have gone this route if they were rubber. Anyway, worst case, I buy shiny new tubulars sometime down the road. Best case, I forget what I did in a couple of years.
A real alignment is a must-do.
Re: front end alignment [Re: BcudaChris] #2648573
04/24/19 06:57 PM
04/24/19 06:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've used the rubber offset Moog bushings on every car I ever done. Wouldn't do one without them. To be honest on regular road conditions I've experienced fast wear with Polyurethane bushings. Went through 3 sets of Moogs on my wifes Caravan.
Doug
Re: front end alignment [Re: mopower440] #2648583
04/24/19 07:29 PM
04/24/19 07:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The last time I had the Cuda aligned, it came into the specs recommended here with offset bushings and the taller spindles. But when I got in the car, we couldn't get it back in spec. Now before you guys start with the cracks, I only weigh 190. And I don't know what a passenger like the wife would do to the alignment. I was really surprised how much my weight affected the numbers.
So what do you guys do? Do you have weight in the driver's seat when you have it aligned? Or do you just have them set it empty? And what about a passenger's weight?
Master, again and still
Re: front end alignment [Re: mopower440] #2648677
04/25/19 01:46 AM
04/25/19 01:46 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Adjustable lower struts will do it. Here is how I did my own car, wrong for most I am sure but it works. First I had the frame squared on a frame machine. I then used a plumb bob to mark center of each axle to floor, then plumb bob center of lower ball joint to floor and made a measurement between them. My wheelbase should have been 116, made it 116-1/4, that gave me the the 2 degrees I wanted, and lower ball ahead of upper like you need. The rear moog strut bushings were too thick for my car, 1970 b-body, factory rear bushing is thinner. I ended up with cut down prothane and cut down sleeves to get it right, and also founds struts varied by 1/8" in length. I found that some moog sleeves were too long also. I also found once you square up the car you find out real fast the k-frame is absolute junk, had to push mine around a little to get everything perfect. A torch, 5 lb hammer and a steel bar will get your stuff in shape. If you do not need the stock look just buy the adjustable strut rods and be done.
Re: front end alignment [Re: mopower440] #2648814
04/25/19 12:07 PM
04/25/19 12:07 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Both my Mopars would barely get any positive caster, and would never feel planted and stable as I drove them. I do have a bit of positive rake on both cars. If you look at a lot of pure stock Mopars, the front end sits higher than the rear. I don't like that look, and set them up so the rear is a bit higher than the front.
It wasn't until I installed the adjustable strut rods that I was able to get a decent amount of positive caster. The cars track straight and are stable even at triple digit speeds with more positive caster. I believe mine are 4 to 6 * positive now. The offset Moog bushings didn't make much difference on my set-up, and I installed them as recommended on this site.
You can machine the stock strut rods to effectively "shorten" their fixed assembled length, or simply buy some adjustable ones. Be sure you do not bind the upper and lower control arms by removing the torsion bars and sweeping them through their full range of travel. It doesn't take much to pull the lower control arm forward enough with the adjustable strut rods to gain positive caster of the suspension assembly.
Re: front end alignment [Re: jbc426] #2648876
04/25/19 02:14 PM
04/25/19 02:14 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Exactly, my frame guy loves them. A set of rods with about 1/4"machined off the front stub and some custom diameter washers would be real nice for us guys that need the stock look. I like the looks of the ones classic industries sells if you want to use stock strut bushings.
