Ever seen a paint daub with a stamped in date code? #2648458
04/24/19 01:21 PM
04/24/19 01:21 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I found this when cleaning up the 741 case from my 1970 Valiant, it is the first time I have seen an 8 3/4" center housing stamped like this.
Cool that is it a 3.23 with what may be the final assembly date of 3-23-70? If so, awesome coincidence. beer
1970 valiant 741 case 3.23 paint daub with stamped date code 1w.jpg1970 valiant 741 case 3.23 paint daub with stamped date code 2w.jpg
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648477
04/24/19 02:16 PM
04/24/19 02:16 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Holy cow. Where is that car from that a marking like that, in that location, survived for 49 years?
Earning every penny of that moderator paycheck.
DBAP
Re: Ever seen a paint daub with a stamped in date code? [Re: not_a_charger] #2648486
04/24/19 02:43 PM
04/24/19 02:43 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
It was ordered new in Colorado, still less than 35K miles.
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648487
04/24/19 02:49 PM
04/24/19 02:49 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
After a 20 minute soak in Evaporust;
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648492
04/24/19 03:00 PM
04/24/19 03:00 PM
That's really amazing. You'd think a paint daub in that location would be really fragile and likely to disappear, even if the car was well maintained. What a cool find.
DBAP
Re: Ever seen a paint daub with a stamped in date code? [Re: not_a_charger] #2648494
04/24/19 03:02 PM
04/24/19 03:02 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
It has paint daubs all over. It still has the factory broken off zerc fittings in the front suspension parts also.
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648505
04/24/19 03:18 PM
04/24/19 03:18 PM
Wow. That would b ea cool car to see a full picture thread on sometime.
DBAP
Re: Ever seen a paint daub with a stamped in date code? [Re: not_a_charger] #2648614
04/24/19 09:05 PM
04/24/19 09:05 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I had to go back through old photos, this one was taken very close to 5 years ago, I just missed the stamped in numbers back then.
Has anyone else ever seen a date code stamp like this on an 8 3/4" housing? It is a new one to me, but if there is one, others are likely out there........
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648661
04/24/19 11:02 PM
04/24/19 11:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Barry is this an LA built car ?
Re: Ever seen a paint daub with a stamped in date code? [Re: autoxcuda] #2648700
04/25/19 08:07 AM
04/25/19 08:07 AM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Hamtramck.
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648745
04/25/19 10:09 AM
04/25/19 10:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think I’ve seen something similar on an LA built 71 340 Demon.
I’ll look through my pics later.
Re: Ever seen a paint daub with a stamped in date code? [Re: autoxcuda] #2648783
04/25/19 11:10 AM
04/25/19 11:10 AM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The broadcast sheet calls for a 752 propeller shaft, it has a date code of 3 70;
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2648995
04/25/19 07:58 PM
04/25/19 07:58 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here's a similar stamp that was on my 71 340 Cuda Convertible. The car has a 331 SPD. Differential is a 3.23 open with small u joints. Don't pay attention to the yellow paint blotches, these are overspray from some earlier body repaint.
Re: Ever seen a paint daub with a stamped in date code? [Re: cudaize] #2648998
04/25/19 08:06 PM
04/25/19 08:06 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Awesome!
Mine has a poor stamp for what may also be CD, but yours is upside down compared to mine.
Thank you!
Does anyone else have any other examples?
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2687128
08/13/19 02:44 AM
08/13/19 02:44 AM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
may be they wear tracking gear sets because of problems in production
Re: Ever seen a paint daub with a stamped in date code? [Re: racerlall] #2687429
08/13/19 08:38 PM
08/13/19 08:38 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I just found another one.
3.23 stamp again, but it is on a 742 case this time.
I'll have to clean it & likely soak it in Evaporust when time allows it so I can get a decent photo.
Re: Ever seen a paint daub with a stamped in date code? [Re: Alaskan_TA] #2687491
08/13/19 11:49 PM
08/13/19 11:49 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
It's more like: "Ever seen a stamped date code with a paint daub"
