Re: Build share
[Re: HardcoreB]
#2853452
11/30/20 04:48 PM
11/30/20 04:48 PM
Posts: 3,009 Sac, CA
mopowers
Sac, CA
Prototype horn button cover from a yogurt lid and wiring clean-up...added trans temp. Man, that looks awesome! What coating did you use on the floor pans?
Re: Build share
[Re: mopar dave]
#2853763
12/01/20 12:31 PM
12/01/20 12:31 PM
Posts: 4,035 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Have to tried any testing with the scoop your using, with and without? Ever tried a cowl scoop. I have been contemplating a scoop for my t ram set up. Curious to what works and what don't. Thanks There are so many good discussions about hood scoops that are worth referencing with one more recently done in this Forum. And yes I have tested with many different styles and cars. I have found generally, fwd facing are the most forgiving to execute some performance benefit. In the end you have to try things and figure out what works with A/F data ideally. The trouble is that most people will say WHY something worked or didnt and be wrong therebty misleading others. Put the bottom of the scoop opening ABOVE the string-line run from the roof to the front of the hood and choose a scoop that has about 3.5" room to the airhorn ( s) Sidebar Q for Alguire if you're still here...care to hazard a guess how much more fluid in quarts than "full cold" I should start the trans level at? There's 4 total in it now (full level cold) and I'm using your old 8" ATI conv which didn't loose any in shipping.
Re: Build share
[Re: HardcoreB]
#2853777
12/01/20 01:18 PM
12/01/20 01:18 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
If it were me 4qts is plenty to fire it up with. As for total capacity will depend on what pan cooler and lines you use. Considering there is likely 1.5ish in the converter you wont need a ton more for sure. Here is what ATI has to say. As for ultimate level I never run them completely full in the shop as you will likely not get enough heat in it to get an accurate read. Although engaging the brake will help put some heat in it. http://www.atiracing.com/instructions/Trans-Converter-Installation.pdf
Re: Build share
[Re: HardcoreB]
#2908448
04/09/21 04:10 PM
04/09/21 04:10 PM
HardcoreB
Shelby Twp. Mi
new tubs fixxed alot of issues: gaps and spliced panels
Re: Build share
[Re: Dartin]
#2912780
04/21/21 09:16 AM
04/21/21 09:16 AM
HardcoreB
Shelby Twp. Mi
As eager as I am to see you get this car wrapped up and racing, I’m glad you put the extra effort in to fixing some of the poor fitting tin work that you had “the other guy” make. The rest of the work is far too nice. It’s a shame you didn’t get what you paid for. Thanks again Randy! and fellas. I just had some updates and I figured I'd add with old/new work...still moving along. As-of last night, I have a cardboard template of hopefully THE LAST two pieces of tin.
