P5 hemi heads #2647964
04/22/19 09:01 PM
04/22/19 09:01 PM
florida dade
cesar perez Offline OP
florida dade
What block is available for p5 hemi heads are they in aluminum or cast
Re: P5 hemi heads [Re: cesar perez] #2647967
04/22/19 09:08 PM
04/22/19 09:08 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You can get 4 cylinder blocks for them everywhere. 8 cyl... not so much.
They were just about giving the 4 cyl blocks away for awhile like under $1000 new in the crate.
Re: P5 hemi heads [Re: TRENDZ] #2648039
04/23/19 12:03 AM
04/23/19 12:03 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: P5 hemi heads [Re: 70AARcuda] #2648042
04/23/19 12:21 AM
04/23/19 12:21 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
The late R4 block isn't great, the bores get very thin at around 4.2"-4.25" and tend to move around and or split. Most of the Aussie Pro Stock stuff has 8 sleeves and are filled. The early blocks are better, but not as good as a Dart Chevy or Ford block.
For anyone that was serious and the rules allowed, a billet aluminium block would be the way to go. You can control how the bores are supported, and the $$$ I've seen the early R4's go for, the prices are very similar
Alan Jones
Re: P5 hemi heads [Re: LA360] #2648148
04/23/19 12:37 PM
04/23/19 12:37 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Does Ritter support the P5 heads?
Re: P5 hemi heads [Re: 340Cuda] #2649987
04/28/19 07:57 PM
04/28/19 07:57 PM
LA360 Offline
LA360  Offline
If it was ordered with blank lifter bores and a blank deck, I'm sure it would work.
Alan Jones
