You need to know first that I hate all of the Mopar house grinds like the Purple Shaft
They are absolute junk in my opinion
To answer your question on cam swapping you need to make sure that none of the lobes are abnormally worn or any visible defects like cracks in the hard coating, especially on the lobe tops
Same thing on the lifters, they need to have no visible wear or marks on the bottoms and they must be put back on the same lobes they where run on in his motor. If they aren't either buy a new cam and lifters or buy all new lifters and break them in like the cam and lifters are new
Do you know how to degree the cam in so you can follow the advice on installing the intake lobe center where the cam grinder wants it install at? If not get help so you can do that
More lift with less duration should make the motor have more low speed power, not less
I can't tell you how many people I know install the cam with the gears dot to dot and had those motors ran like horse Doo Doo
I had that happen on the first solid roller cam I installed in a boat motor, I lined up the dots and check the cam timing and thought it was "close enough" and it sounded great when running without a load on the motor, in the water in gear that motor would not rev past 300 RPM, it would run over 6500 RPM with the old solid lifter cam in it
It was ground 10 degrees retarded on the intake lobe timing, the alignment pin was install wrong by the cam grinder
I never install any cam dot to do any more, NEVER
