Re: Undiluted for Indy Slots
[Re: DAYCLONA]
#2647669
04/21/19 10:57 PM
04/21/19 10:57 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
I agree that the backside would tell. To me, on my ipad, they look like a unilug oval. I’m not a fan, but if that’s the case then the damage on the other side doesn’t add to the issue once mag lugs and washers are used.
If however they are NOT unilug, then they are damaged beyond use. Being hub centric, the center hub positions the wheel, not the lugs, so the wheel is not "damaged beyond use" if the correct lugs and washers are used, even if the lug holes were "ovaled" out from improper prior hardware .... True, I did not consider that.
[Re: TJP]
#2647787
04/22/19 11:16 AM
04/22/19 11:16 AM
Posts: 19,408 north of coder
moparx
every aftermarket wheel i have ever seen with a unilug pattern were NOT hubcentric unless you used those rings to make them so. and those rings were not [readily] available until several years ago. as has already been mentioned, the ford, mopar, and GM hubs are all different in diameter, and the "common" hub bore on aftermarket wheels is roughly 3.??? ID. so they fit every possible application. a real common way to make those wheels look like the ones the OP has, is "losing" the washers, and using the correct lugnuts, or using factory style lugnuts. i saw this ALL the time in my junkyard ownership years [1972-1984 when those wheels were new] there are several ways to simply fix those wheels, but it will require a machine shop [or a good friend that has a bridgeport and knows how to use it].
Re: Unilug Indy Slots
[Re: dart4forte]
#2647800
04/22/19 11:54 AM
04/22/19 11:54 AM
Posts: 1,707 central il.
second 70
central il.
I worked at Goodyear in the 70’s and some rims only used an offset washer on the front while others had inserts that also went in the back of rims. Here is a set of “don’t kill me” Chevy lugs from a set of Ansen Sprint rims. The inserts are about 5/8 thick and push in the rear of rim. The Chevy were in the center and you would need the other insert which would move them in or out. Threw the Mcguard wheel locks in for nostalgia.
Mike
Wow just realized these lugs are 45 years old and the chrome is perfect!
[Re: second 70]
#2647808
04/22/19 12:26 PM
04/22/19 12:26 PM
Posts: 9,839 MI, usa
dvw
MI, usa
Mike
Wow just realized these lugs are 45 years old and the chrome is perfect! I believe these style lugs were Appliance brand wheels. Doug
[Re: dart4forte]
#2647809
04/22/19 12:28 PM
04/22/19 12:28 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Yes, they are hub centric. Here’s another view
I have two other wheels just like this pair. Backside
Abe Lincoln
[Re: dvw]
#2647946
04/22/19 08:11 PM
04/22/19 08:11 PM
second 70
central il.
I believe these style lugs were Appliance brand wheels. Doug [/quote]
Doug they were called Ansen sprint 2. I bought the rims new back in high school. The original sprints weren't unilug. But come to think of it maybe Ford were center and Chevy were offset?
[Re: second 70]
#2647996
04/22/19 10:26 PM
04/22/19 10:26 PM
dvw
MI, usa
Doug they were called Ansen sprint 2. I bought the rims new back in high school. The original sprints weren't unilug. But come to think of it maybe Ford were center and Chevy were offset? [/quote Sprint II were unilug only. I just remember round washers that fitted into a front recess. Doug
[Re: 6bblgt]
#2648082
04/23/19 09:35 AM
04/23/19 09:35 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
I recently put two sets of slotted mags on two of my cars. The set that I put on my van were made by US mags and they looked like the wheel posted by the OP. They used the standard shank type lugs with standard centered washers. I bought a set of them from Auto Zone, that were made by Dorman, and they are total made in China crap.They were stripping the threads out while I was installing them by hand with a socket and a ratchet. If you need to get a set,buy them from Summit Racing or Jegs,and buy American Racing, Cragar, or Mcguard lugs. How they can sell substandard lug nuts to hold the wheels on your vehicle, with poor metallurgy is beyond me! Anyway, the second set of slotted wheels consisted of a pair from American Racing which also used the standard shank type lugs and standard centered washers,and a pair of Anson slotted wheels that used the oval shaped washers that fit into a machined out recessed area around the lug holes. Those wheels used the oval washers with the offset lug holes that fit into the recessed area of the rim,with standard shank type lug nuts.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: dvw]
#2648124
04/23/19 11:49 AM
04/23/19 11:49 AM
second 70
central il.
Doug those cleaned up great. Here's a picture of the back of the Ansen 2. You can see two of the inserts are installed. Who ever put them in have have at least one backwards. Lol
[Re: 6bblgt]
#2648146
04/23/19 12:35 PM
04/23/19 12:35 PM
moparx
unless there is more side to side damage than it appears …..
with the proper mag wheel shank lug nuts properly torqued those wheels won't go anywhere your picture brought back my old mind from hibernation ! back around the eary, or mid 80's, my brother bought a set of chromed steel slots. it had a ford/chevy pattern where the lugs fit as your picture suggests. once they were tightened, they weren't going anywhere. [provided the holes were not buggered up]. there may have been aluminum wheels like that, but i have never seen any to investigate the hole to lugnut fit.
[Re: dvw]
#2648195
04/23/19 03:36 PM
04/23/19 03:36 PM
second 70
central il.
Man this taxing my old guy memory. Worked there in 1974 Doug Tell me about it Lol I believe these rims came with 2 different bushings. A center hole for 4.75 Chevy and a .25 offset that you could use to make them 4.5 Mopar, Ford, or 5" Chevy truck. Also there was another rim I think ET that had a one piece plastic insert with all the bushings attached like fingers that went in the back. It looked just like 6bblgt's picture. So with those rims there where 3 different inserts since they were one piece.
