Bed Roll Lights #2647272
04/20/19 02:39 PM
04/20/19 02:39 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Thinking of adding bedroll lights to my 74 Stepside. Who’s running them and how are they wired?
https://www.chevsofthe40s.com/dept/Lights/cat/Bed+Roll+Lights.html
Abe Lincoln
Re: Bed Roll Lights [Re: dart4forte] #2647293
04/20/19 03:25 PM
04/20/19 03:25 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Originally Posted by dart4forte
"bedroll lights"
That sent me to Google. Anybody else? confused
Re: Bed Roll Lights [Re: John_Kunkel] #2647297
04/20/19 03:51 PM
04/20/19 03:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I figured it had to do with camping.
Don't be the exception.
Re: Bed Roll Lights [Re: Supercuda] #2647313
04/20/19 04:50 PM
04/20/19 04:50 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
"74 Stepside".
I was thinking, wrong forum? whistling
No idea what a "Bed Roll Light" is. shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Bed Roll Lights [Re: bboogieart] #2647324
04/20/19 05:28 PM
04/20/19 05:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
bed roll light
Re: Bed Roll Lights [Re: Supercuda] #2647327
04/20/19 05:35 PM
04/20/19 05:35 PM
Mesa, Arizona
Mesa, Arizona
Originally Posted by Supercuda
bed roll light
There ya go
Abe Lincoln
Re: Bed Roll Lights [Re: dart4forte] #2647339
04/20/19 06:08 PM
04/20/19 06:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
So just a small diameter led lite.
Neat application.
So yeah street rod not pick-up per say.
Can you pull the wires from the front of the bed roll?
Signal or running lights or both should be able to tap into the in cab lighting harness.
Re: Bed Roll Lights [Re: bboogieart] #2647367
04/20/19 07:50 PM
04/20/19 07:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's a tail light, not just a light and not always LED either. They've been around for decades.
Re: Bed Roll Lights [Re: Supercuda] #2647504
04/21/19 10:12 AM
04/21/19 10:12 AM
moparx Offline
moparx  Offline
if a guy uses a dual filament [led or standard bulb] they can be wired as brake and turn lights as well as just decorative running lights.
beer
Re: Bed Roll Lights [Re: Supercuda] #2647528
04/21/19 11:48 AM
04/21/19 11:48 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Kinda redundant huh?
Oh well, never mind, have a Happy Easter. up
Re: Bed Roll Lights [Re: bboogieart] #2647536
04/21/19 12:06 PM
04/21/19 12:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's only redundant is you leave the stock tail lights, which is not usual.
Re: Bed Roll Lights [Re: Supercuda] #2647635
04/21/19 09:15 PM
04/21/19 09:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I made my own bed rail lights for my 54 Dodge 20 years ago. I treated them as a 3rd brake (and turn) light on each side of the truck. My tail lights were in a panel below the tailgate. The lights that were available then didn't fit in the bed rail roll very well. I pulled additional wires off the brake/turn signal wires for each side. I drilled a small hole (big enough for the hot wire and a ground and a little clearance) at the top of the stake pocket and at the back bottom corner of the bed rail roll. I modified a plastic pipe plug that fit into the rail roll to hold a light. The light was brake light bright, and functioned with the brake lights and turn signals. A set screw in the end of the rail held the light "socket" in place. The method I used to fit the light in the plastic holder put the end of the bulb flush with the end of the plastic that was nearly flush with the end of the rail.
My 54 had a bit of a nose down rake, so sitting in a car that was behind the truck, the light in the rail roll was at a pretty high angle and provided very little additional lighting effect. It looked great if you were standing behind the truck though.
Pictures of the truck showing the lights in the bed rail roll are long gone. Gene
Re: Bed Roll Lights [Re: dart4forte] #2647984
04/22/19 10:02 PM
04/22/19 10:02 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
