Re: Master Cylinder, drum to disk swap?
[Re: mopower440]
#2647466
04/21/19 06:27 AM
04/21/19 06:27 AM
Posts: 1,487 STL
cdstl
STL
Since you have a manual set up, get a MC with a 15/16" bore. Like this... https://www.manciniracing.com/ristdemacy.html
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: mopower440]
#2647508
04/21/19 10:19 AM
04/21/19 10:19 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
15/16" disc master, 4 bolt cast iron
RAYBESTOS MC36406
CENTRIC 13063017
CARDONE 131571
73-75 Dart with power discs is the application.
[Re: Supercuda]
#2647576
04/21/19 02:53 PM
04/21/19 02:53 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
Well, i got the front end together today and even though i have not got the correct master cylinder yet, i had to take it for a ride. I was happy with how much better it drove, BUT, the brakes barely worked! I can stand on them and the car just creeps to a slow stop. Granted, its still got the drum/drum MC on it,, but shouldnt it still stop fairly decent? I couldnt even make them lock up in my gravel driveway doing 30! It has a good solid pedal, just dont stop worth a darn..
[Re: mopower440]
#2647579
04/21/19 03:46 PM
04/21/19 03:46 PM
Supercuda
About to go away
About to go away
up yours
Drum brakes of that era are self energizing.
Without going into a bunch of technical stuff, they don't need as much pedal effort for a given amount of braking force.
Disc brakes are not self energizing.
[Re: mopower440]
#2647592
04/21/19 05:27 PM
04/21/19 05:27 PM
RapidRobert
BUT, the brakes barely worked! I can stand on them and the car just creeps to a slow stop. Granted, its still got the drum/drum MC on it,, but shouldnt it still stop fairly decent? I couldnt even make them lock up in my gravel driveway doing 30! It has a good solid pedal, just dont stop worth a darn.. Yes there is still an issue (fluid restriction somewhere is my guess). Once I had that & it was a partially crimped brake line.
[Re: RapidRobert]
#2647617
04/21/19 07:32 PM
04/21/19 07:32 PM
mopower440
middle Tennessee
BUT, the brakes barely worked! I can stand on them and the car just creeps to a slow stop. Granted, its still got the drum/drum MC on it,, but shouldnt it still stop fairly decent? I couldnt even make them lock up in my gravel driveway doing 30! It has a good solid pedal, just dont stop worth a darn.. Yes there is still an issue (fluid restriction somewhere is my guess). Once I had that & it was a partially crimped brake line. when bleeding them i can make the pedal go to the floor, pushing plenty of fluid..
[Re: mopower440]
#2647638
04/21/19 09:20 PM
04/21/19 09:20 PM
RapidRobert
Alright it does sound like there is no fluid restriction. that pretty much does point to a bore mismatch assuming the hard parts are functioning/moving as they should.
[Re: RapidRobert]
#2647647
04/21/19 09:40 PM
04/21/19 09:40 PM
mopower440
middle Tennessee
Alright it does sound like there is no fluid restriction. that pretty much does point to a bore mismatch assuming the hard parts are functioning/moving as they should. Im wondering if the pistons in the calipers are frozen up and just barely moving?
[Re: mopower440]
#2647651
04/21/19 09:48 PM
04/21/19 09:48 PM
RapidRobert
this wouldn't be the same inertia amt as a moving vehicle but I would jack it up & spin the front wheels by hand & see if the pedal stops em firmly/quickly. EDIT & you could bearhug each rim (forward) with your helper on the pedal & see if they budge (& they're up in the air if you need to go into em).
[Re: RapidRobert]
#2647948
04/22/19 08:19 PM
04/22/19 08:19 PM
mopower440
middle Tennessee
Ya, they are stuck/sticking. I pulled them off and put air to them and on one of the calipers, only one side moves and the others that do move wont hardly retract. To save some money, i thought about rebuilding them myself rather than buying calipers.. Also,I have MANUAL Kelsey hayes brakes on my 1972 dart, I see most people like the 15/16 bore MC for manual discs..well, looking at my local oreilly, all the master cylinders for manual brakes are 1.032 inch..in order to get a 1 inch bore MC i have to get one for POWER disc/drum brakes..is that ok to do or do i have to have one that is strictly for manual brakes? I would like to pick one up tomorrow..
[Re: mopower440]
#2648007
04/22/19 10:47 PM
04/22/19 10:47 PM
RapidRobert
look down in the rear MC piston "thimble" & if it has a circular recess about halfway down in there then yes it will work for manual brakes as that is where the piece of neoprene slipped on the end of the manual brake pushrod locks into. If the MC does not come with that piece of neoprene you can cut a piece of neoprene fuel line. the piece that comes with manual MC's looks the same ex for a thin groove along its length tho I dont know if that is a mfr oddity that serves no purpose or if it is there to let air excape so it will lock into the recess better & either way you can cut that thin groove your self & they oughta have a manual MC on the shelf that has one of those tailor made pieces so you can see for your self. power brake MC's do not need that piston recess but can use a MC with or without the recess. EDIT manual brakes DO need that recess
