swaping out stock road runner hood for a scooped hood #2646597
04/18/19 08:11 PM
04/18/19 08:11 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I am thinking about swapping out my stock road runner hood for a fiberglass A-12 type hood. I see several places sell them online like AMD and AAR.
Which is the best and is it how difficult is the install? I would like to have it painted to match too so i know it will need to go to a body shop of course.
Thank you for your advice
Stu
https://www.aarqualityfiberglass.com/products/hood-road-runner-1968-1969-six-pack-bolt
Re: swaping out stock road runner hood for a scooped hood [Re: MidPenMopar] #2646599
04/18/19 08:16 PM
04/18/19 08:16 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Flat hoods are sexy. twocents
Re: swaping out stock road runner hood for a scooped hood [Re: Alaskan_TA] #2646625
04/18/19 09:44 PM
04/18/19 09:44 PM
BDW Offline
BDW  Offline
No experience with Roadrunner hood, but I have AAR T/A hood and it’s nice.
Fit and finish was perfect, painted and bolted it on with no mods.
Re: swaping out stock road runner hood for a scooped hood [Re: BDW] #2646643
04/18/19 10:26 PM
04/18/19 10:26 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Keep in mind how you'll hold it up. Most fiberglass hoods don't take well to stock hinges/hood springs.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: swaping out stock road runner hood for a scooped hood [Re: GoodysGotaCuda] #2646647
04/18/19 10:40 PM
04/18/19 10:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Mine is a VFN - made for hood hinges (with light springs obviously). Its beautifully made and fits well. The one thing it has ove all others is its has an original style flange above the grill. This does two things ... 1) it ads rigidity to the front and 2) it provides the correct shape around the headlight buckets. HOWEVER ... the original A12 hoods were molded from Belvedere/Satellite hoods and have the center bulge treatment. The VFN hood does not have that bulge - the hood is flat in that area giving it a very clean look.
Re: swaping out stock road runner hood for a scooped hood [Re: Stanton] #2646675
04/19/19 12:13 AM
04/19/19 12:13 AM
Thank you
Do you have a link for it please?
Re: swaping out stock road runner hood for a scooped hood [Re: MidPenMopar] #2646725
04/19/19 08:43 AM
04/19/19 08:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Let me go and have a look at my hood. It may be a Glasstek instead of VFN (I always get them mixed up).
Here's a link to Glasstek: http://glasstek.com/products/plymouth/road-runner/h7050/
Re: swaping out stock road runner hood for a scooped hood [Re: Stanton] #2646731
04/19/19 08:57 AM
04/19/19 08:57 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Stu - I vote for keeping your original hood. It matches the rest of the car.
If you change you will need to match the paint and striping.
Then you will have to seal the air cleaner to the hood otherwise it looks bad and just scoops bugs into the engine compartment.
Re: swaping out stock road runner hood for a scooped hood [Re: Stanton] #2646789
04/19/19 11:09 AM
04/19/19 11:09 AM
Thank you for the link.
Just doing some thinking about changing things up a bit for a new look. I have a buddy who is a body and paint guy so he could match the color no problem he said.
Re: swaping out stock road runner hood for a scooped hood [Re: MidPenMopar] #2646946
04/19/19 07:35 PM
04/19/19 07:35 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
The a12 scoop is the most awesomest B body scoop ever. The standard RR hood is merely okay.
Re: swaping out stock road runner hood for a scooped hood [Re: forphorty] #2646996
04/19/19 09:17 PM
04/19/19 09:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So mine IS a VFN. Photos attached. You can see the front lip I mentioned that goes across the underside of the front and maintains the shape around the headlights. Many 'glass hoods fall short in that area - they trim too much or don't have the correct curve. Also note the flat nose. They don't have the stock shape on the underside but its still quite rigid - I think they lay in more glass in the bolt-on hood versus the pin-on which is paper thin. I do like the underside of the Glasstek hood but I bought this one used so didn't really have the option and since I haven't seen one other than in pictuires, can't speak to the quality.
Re: swaping out stock road runner hood for a scooped hood [Re: Stanton] #2647167
04/20/19 10:19 AM
04/20/19 10:19 AM
Thank you very much for the photos and info!!
Stu
