Torn lower ball joint boot? #2644824
04/13/19 08:45 PM
04/13/19 08:45 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
I got one side of the dart back together today, doing the front end rebuild and K-H brake swap. I did have a problem and that was trying to get the freaking dust boot seated on the lower ball joint which are moog brand. I FINALLY found a piece of PVC pipe the right size and smacked it on using the pipe, but i did tear one of the boots, so im held up from doing the other side until i can figure out how to get another boot without buying another whole lower ball joint..anyone know where i can get that correct boot? I really do NOT want to put on a torn boot..
Re: Torn lower ball joint boot? [Re: mopower440] #2644826
04/13/19 08:47 PM
04/13/19 08:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
https://www.speedwaymotors.com/shop/ball-joint-boots~8-10891
Don't be the exception.
Re: Torn lower ball joint boot? [Re: mopower440] #2644827
04/13/19 08:49 PM
04/13/19 08:49 PM
70duster340 Offline
70duster340  Offline
You can get replacement boots in the Help section of the local parts store. I had to get one myself.
Re: Torn lower ball joint boot? [Re: 70duster340] #2644839
04/13/19 09:26 PM
04/13/19 09:26 PM
middle Tennessee
middle Tennessee
really? Would it fit the moog do you think?
Thanks!
Re: Torn lower ball joint boot? [Re: mopower440] #2644843
04/13/19 09:49 PM
04/13/19 09:49 PM
n.c.
geo. Offline
geo.  Offline
n.c.
How big is the hole?
try an inner tube patch after cleaning the snot out of it!
Re: Torn lower ball joint boot? [Re: mopower440] #2644859
04/13/19 10:38 PM
04/13/19 10:38 PM
70duster340 Offline
70duster340  Offline
It should fit. Summit carries poly boots if that interests you.
Re: Torn lower ball joint boot? [Re: 70duster340] #2644908
04/14/19 06:49 AM
04/14/19 06:49 AM
middle Tennessee
middle Tennessee
Im going to check the help section today for sure. Any certain parts house you are referring to that you saw them at?
Thanks!
Re: Torn lower ball joint boot? [Re: mopower440] #2644922
04/14/19 08:12 AM
04/14/19 08:12 AM
70duster340 Offline
70duster340  Offline
Yeah, try Advance Auto.
Re: Torn lower ball joint boot? [Re: 70duster340] #2646232
04/17/19 09:15 PM
04/17/19 09:15 PM
middle Tennessee
middle Tennessee
ell, i got the new energy suspension ball joint boots and dont know if i should use them or just glue the tear in the moog boot. The reason im pondering it is because the energy suspension boot just sits over the ball joint and doesnt actually seal around the bottom like the moog boot does, so the grease can just come right out the bottom...anyone used these from energy suspension and had good luck with them? here is a pic of the torn moog boot that actually seals to the bottom of the ball joint and you can see the rip.
Re: Torn lower ball joint boot? [Re: mopower440] #2646269
04/17/19 10:58 PM
04/17/19 10:58 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Save the money and effort by passing on those dorman help universal junk things, in about 3 months it will be cracked and falling apart.
Re: Torn lower ball joint boot? [Re: 135sohc] #2646381
04/18/19 09:06 AM
04/18/19 09:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I already sent you teh link you needed.
https://www.speedwaymotors.com/Replacement-Screw-In-Ball-Joint-Dust-Boot-K772-Application,100099.html
Re: Torn lower ball joint boot? [Re: Supercuda] #2646394
04/18/19 09:46 AM
04/18/19 09:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have the same rip in one of mine ! As far as the ES boots just "sitting there", there should be enough tension in the material to keep the boot seated, grease in and dirt out. The grease feeds in from the bottom of the BJ so the grease in the boot serves little purpose. Assemble the front end, lube it, clean up the mess and drive it.
Re: Torn lower ball joint boot? [Re: Stanton] #2646396
04/18/19 09:49 AM
04/18/19 09:49 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Damn ... shipping will probably be $20 !!!
Re: Torn lower ball joint boot? [Re: Stanton] #2646417
04/18/19 10:25 AM
04/18/19 10:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Shipping is free if you amass $100 or more of stuff.
Look around bet you can do that easy there.
Or $4.78 to me if I am not in a hurry
Re: Torn lower ball joint boot? [Re: Supercuda] #2646497
04/18/19 02:53 PM
04/18/19 02:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Curious how Speedway manages to have them but NOBODY else does !!!
Re: Torn lower ball joint boot? [Re: Stanton] #2646502
04/18/19 03:05 PM
04/18/19 03:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They are on clearance so they may not have them for llong
