PST LCA Bushings #2645746
04/16/19 04:22 PM
04/16/19 04:22 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
So I was putting my front suspension back together and ready to do the brakes, when I realized the LCA inner sleeve pulled out of the rubber when I hand tightened the pivot shaft to the K member. I was just wondering if anyones experienced this before. Are you not supposed to tighten the pivot shaft AT ALL until the weight is on the ground?
Re: PST LCA Bushings [Re: 70charger512] #2645800
04/16/19 07:56 PM
04/16/19 07:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, you got junk bushings.
The reason you don;t tighten certain bushings until weight is on the then is so as to not preload the rubber. If you just tightend that nut without any load on the LCA and it came apart you have junk bushings.
Don't be the exception.
Re: PST LCA Bushings [Re: 70charger512] #2653842
05/09/19 09:29 PM
05/09/19 09:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Do you have rubber or Poly lower bushings from PST?
Re: PST LCA Bushings [Re: DAYCLONA] #2653930
05/10/19 08:11 AM
05/10/19 08:11 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
I have the rubber, but I think I figured out what I did wrong, I have an adjustable strut rod, and had it too long (despite being the length the instructions said), so the control arm couldn't move forward anymore, and the only possibility was pulling out the bushing.
Re: PST LCA Bushings [Re: 70charger512] #2655611
05/15/19 07:54 AM
05/15/19 07:54 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
