True trac or Trac-Loc for street?
#2645750
04/16/19 04:29 PM
04/16/19 04:29 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
I'm looking at getting a dana 60 my my car that is mainly street driven with a few trips to the drag strip every now and then. Would I be better off with the True trac or trac-loc unit? Any advantages or disadvantages to either? Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: True trac or Trac-Loc for street?
[Re: 73cuda340]
#2645755
04/16/19 05:33 PM
04/16/19 05:33 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I have the Strange S trac, in my S60, works AWESOME street strip, it works the same as the Eaton true trac version but it is stonger.
[Re: dangina]
#2645757
04/16/19 05:35 PM
04/16/19 05:35 PM
73cuda340
clarks summit pa
The rear is listed as coming with a trac-loc clutch posi with the 35 spline true-trac as an upgrade.
[Re: 73cuda340]
#2645821
04/16/19 08:28 PM
04/16/19 08:28 PM
CSK
Pattison Texas
Are you buying a new Strange s60 ? they offer as an upgrade the Eaton AND Strange helical carrier, the Strange unit is a better unit & cost more than the Eaton.
[Re: 73cuda340]
#2645835
04/16/19 09:11 PM
04/16/19 09:11 PM
Posts: 171 Las Vegas, NV
chargerbr549
Las Vegas, NV
I don't have any experience with a True trac but the Trac-loc came in the Dana 60's I believe somewhere around 1970 and newer and were not that great of a posi, it didn't take alot of torque to break them loose and they wore out fairly quickly. My preference would be a Powr-Lok that the factory used from 1966-1969 and I believe the aftermarket makes them. In all my 8 3/4's I run the Power-Lok posi's (oh the purists will correct me on it being a "Suregrip" and not a "Posi" oops) and they work great and you can set them up fairly tight or looser depending on your preference. Here is a link to Dr Diff he is a great source for parts. https://www.doctordiff.com/drivetrain/dana-60/
[Re: chargerbr549]
#2645845
04/16/19 09:51 PM
04/16/19 09:51 PM
73cuda340
clarks summit pa
Im not sure which one I'm getting yet. The strange was one of the danas that I was looking at.
[Re: 73cuda340]
#2645873
04/16/19 10:43 PM
04/16/19 10:43 PM
CSK
Pattison Texas
Dr diff is who I got my S60 from.
[Re: CSK]
#2645944
04/17/19 08:30 AM
04/17/19 08:30 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
If you're buying a brand new complete unit, get the Strange S60 from Dr. Diff. Always heard the trac-locks are pretty weak. The factory Power-Lock is a much beefier unit. Both of my cars have spools and my dad's road runner has a Power-Lock in it.
I have a Moser M60 under my 'cuda that's been flawless since 2003, but it doesn't have the convenient side adjusters for setting backlash like the Strange S60 does.
You could always save some money if you're willing to do some work yourself and cut down a truck Dana.
[Re: CSK]
#2646022
04/17/19 12:03 PM
04/17/19 12:03 PM
BradH
I have the Strange S trac, in my S60, works AWESOME street strip, it works the same as the Eaton true trac version but it is stonger. I have the same setup as above in the S-60 I bought from Dr. Diff.
