PST Poly UCA Bushings #2645650
04/16/19 09:08 AM
04/16/19 09:08 AM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
I assume plenty of people have dealt with poly upper control arm bushings, but I have a question involving the install. I used the bushing press to get two of them in, and they're snug, but the other two slid in by hand, and I can push them out by hand. The guys at PST assured me it was ok, but I wanted to know what you guys thought?
Re: PST Poly UCA Bushings [Re: 70charger512] #2645658
04/16/19 09:33 AM
04/16/19 09:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
At one time Mopar made some retainer rings for those bushings. But I'll be darned if I can remember why or where I saw them for sale.
Don't be the exception.
Re: PST Poly UCA Bushings [Re: 70charger512] #2645740
04/16/19 03:34 PM
04/16/19 03:34 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
No, not OK. Precisely why I deal with Firm Feel for suspension parts.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: PST Poly UCA Bushings [Re: 70charger512] #2653843
05/09/19 09:35 PM
05/09/19 09:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd get another upper set of arms, repros and aftermarket are available assuming your using original/used arms currently?
Re: PST Poly UCA Bushings [Re: 70charger512] #2653929
05/10/19 08:08 AM
05/10/19 08:08 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
I received new free control arms from Doctor Diff (with free next day shipping, it only took 18 hrs to get to my house). The poly bushings fit perfectly, the weird thing I discovered was in the bad control arms the poly bushings would slide in by hand, but the rubber ones that came with then didn't.
Re: PST Poly UCA Bushings [Re: 70charger512] #2655613
05/15/19 07:56 AM
05/15/19 07:56 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
just like your last post....you have junk bushings
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: PST Poly UCA Bushings [Re: yella71] #2655619
05/15/19 08:24 AM
05/15/19 08:24 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
I used the same poly bushings in the new control arms and they fit perfectly. It's weird in the bad UCA's, the rubber ones fit fine, but the poly ones didn't, but those same poly ones fit in the new control arms.
Re: PST Poly UCA Bushings [Re: 70charger512] #2655636
05/15/19 09:44 AM
05/15/19 09:44 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
does one pair of control arms have the outer shell still pressed in while the other paid doesn't?
also, from your other thread, and a similar thing happened to me...the strut rod locates the whole lower control arm well enough that if the strut rod is too long for some reason, you can use the LCA pivot bolt to actually pull the pivot pin out of the LCA. think about how much locating fore and aft the LCA bushing is actually doing.
