Small block vs big block frame #2645399
04/15/19 02:07 PM
04/15/19 02:07 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
We are attempting to build a police package out of a 74 Monaco. The car was originally a 318 car. We have a real K code 440 Fury cop car as a donor to swap into the Monaco. Already we have learned that a Mancini motor mount kit was required as welded brackets on K member are different location. Also had to rewire as distributor is in different location. Before we go further:
Are the small block and big block power steering boxes in the same location? The line sizes are different but bolt holes look the same. Thought I would check here before tearing it open. Thanks
PS If you want a big block car, start with one.
CALMED THE QUAKE!!!(AGAIN!)
Re: Small block vs big block frame [Re: Spyphish] #2645403
04/15/19 02:19 PM
04/15/19 02:19 PM
IMGTX Offline
IMGTX  Offline
The steering boxes and linkage geometry are the same but the torsion bars will be different. Especially on a cop car the torsion and swap bars should be different.
Re: Small block vs big block frame [Re: IMGTX] #2645434
04/15/19 04:25 PM
04/15/19 04:25 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Yep and Larger T bars and antiroll swapped fine. Thanks for the help
Re: Small block vs big block frame [Re: Spyphish] #2645449
04/15/19 04:57 PM
04/15/19 04:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Only diff related to K member making them diff between BB and SB are the engine mount locations. Otherwise is the same K Member. Rest of related parts simply interchange accordingly to the car setup.
Re: Small block vs big block frame [Re: NachoRT74] #2645530
04/15/19 09:08 PM
04/15/19 09:08 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The steering box is the same, and the power steering pump is the same, but the brackets that hold the power steering pump on the motor are different. All the brackets on the front of the motor are different between the small block and the big block. You will need the big block brackets for the power steering pump, alt, and AC.
Exhaust and radiator (depending on which big block water pump housing you have) are different as well. Gene
Re: Small block vs big block frame [Re: poorboy] #2645618
04/16/19 06:13 AM
04/16/19 06:13 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
We have a complete rust bucket donor BB cop motor with the brackets, coolers and radiator. Sounds like it will move right over since we solved the motor mount issue. Thanks
