Re: axle backlash adjustment
[Re: Andrewh]
#2645498
04/15/19 07:51 PM
04/15/19 07:51 PM
Posts: 10,726 North Dakota
6PakBee
North Dakota
If I am pulling the axles and putting them back in the same rear end, if I don't mess with the back lash adjustment, do I need to check anything? {Yes, you should recheck the axle end play}
what happens if it is off? {Too tight or too loose, accelerated bearing wear}
8 3/4 with a 742 one-legger. {Doesn't matter}
[Re: Andrewh]
#2645608
04/16/19 04:55 AM
04/16/19 04:55 AM
Posts: 5,836 ohio
ruderunner
ohio
That's exactly what it is.
Angry white pureblood male
[Re: ruderunner]
#2645723
04/16/19 02:20 PM
04/16/19 02:20 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Not preload but free-play. Preload, like on the pinion and carrier bearings, applies constant load on the bearings while free-play allows the axles to move a little.
[Re: Andrewh]
#2655298
05/14/19 10:55 AM
05/14/19 10:55 AM
6PakBee
North Dakota
This link should explain everything you need to know. 8 3/4 Adjustment
[Re: Andrewh]
#2655320
05/14/19 12:11 PM
05/14/19 12:11 PM
RapidRobert
what part(s) are missing exactly? Just the flat lock tab with the "tang". When resolved, adj it to .010" end play. I like to go in solid then come back out to .010". Why were the axles pulled?
[Re: Andrewh]
#2655389
05/14/19 03:09 PM
05/14/19 03:09 PM
John_Kunkel
Rio Linda, CA
If there is no adjuster, somebody might have replaced the original axle bearings with the Green ball bearings. Some pics would help.
