flex plate ?? #2645215
04/14/19 11:12 PM
04/14/19 11:12 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
what flex plate is used with a magnum 360 and a 727 10 3/4 natural balance factory converter ?
thank you !
Re: flex plate ?? [Re: calrobb2000] #2645412
04/15/19 02:52 PM
04/15/19 02:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The B&M #10242 is for use with the 360 Magnum and a neutral balanced converter.
EDIT: Oops, discontinued.
Re: flex plate ?? [Re: calrobb2000] #2645502
04/15/19 08:03 PM
04/15/19 08:03 PM
Originally Posted by calrobb2000
hi
thank you !
Do you mean a neutral balance converter? If so your probably out of luck on that deal now whiney
The only other alternative I can think of to be able to use that converter safely is to have the motor neutral balanced shruggy work
Sorry
Re: flex plate ?? [Re: calrobb2000] #2645516
04/15/19 08:42 PM
04/15/19 08:42 PM
Australia
dodgy Offline
dodgy  Offline
Australia
Re: flex plate ?? [Re: dodgy] #2645543
04/15/19 09:40 PM
04/15/19 09:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Call Lenny at Ultimate Converters and see what he can do for ya
wave
Re: flex plate ?? [Re: calrobb2000] #2645546
04/15/19 09:50 PM
04/15/19 09:50 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If you cannot locate a balanced flex plate I have used to mopar weight kit and tack welded them on the converter several times. They give you measurements where they go. I have done it several times in the car, and never even drained the fluid.
https://www.manciniracing.com/mopbalweigpa.html
