So I have a fuel sending unit out of a 91 Dakota, and I need to know the ohm reading range it operates in. I need the ohm readings to set my aftermarket fuel gauge.
Also would like the same info for a 2005 Durango fuel sending unit if possible. Thanks, Gene
