Victor intake #2644506
04/12/19 06:58 PM
04/12/19 06:58 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I have a 71 Challenger with a 440 in it. I would like to put a Victor intake on it but not sure of the height on my R/T hood. Will it fit? Thanks
Re: Victor intake [Re: Shatar4] #2644550
04/12/19 09:42 PM
04/12/19 09:42 PM
New York, USA
Chargerfan68 Offline
New York, USA
Im not exactly sure in your application, but i would guess not. It is a pretty tall intake. I have it on my 68 b body and it won’t fit under the stock hood- charger.
Re: Victor intake [Re: Shatar4] #2644621
04/13/19 08:17 AM
04/13/19 08:17 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
R/T hood, not likely; T/A hood in your profile pics, yes.
Re: Victor intake [Re: BradH] #2644630
04/13/19 08:57 AM
04/13/19 08:57 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I have a Super Victor off the engine I could measure for you,
let me know if that will help.
Joe
Re: Victor intake [Re: BradH] #2644648
04/13/19 09:51 AM
04/13/19 09:51 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
[i][/i]
That is an old pic. I have a R/T hood on it now.
Re: Victor intake [Re: jlatessa] #2644649
04/13/19 09:52 AM
04/13/19 09:52 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Joe
That would be awesome! I appreciate it.
Re: Victor intake [Re: Shatar4] #2644653
04/13/19 09:58 AM
04/13/19 09:58 AM
BradH Offline
BradH  Offline
Standard Victor RB intake is 6"+ from the base to the carb mounting surface, and it's not tilted forward like an OEM or most aftermarket intakes, either.
Re: Victor intake [Re: BradH] #2644663
04/13/19 10:26 AM
04/13/19 10:26 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
My un-molested Super Victor is 6-3/8" to the carb base lying on flat surface.
Max Wedge runner dimension would account for the difference, I assume.
Joe
Re: Victor intake [Re: jlatessa] #2644700
04/13/19 11:27 AM
04/13/19 11:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would be surprised if it fits under a stock hood with a 440. I have the same problem on my 63 as I run the Indy dual plane and would like to try a single plane one day. I think the only two that will fit are the Holley SD and the Mopar 337 intake. I want to try the Mopar 337 one day as I hear its a very good single plane and it may fit under your hood also. Good luck , Ron
