Page 1 of 4 1 2 3 4
For Sale - Small Block Engine - 2nd Quarter #2639343
03/31/19 08:13 PM
03/31/19 08:13 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Blocks, heads. [Re: moparts] #2639404
03/31/19 10:44 PM
03/31/19 10:44 PM
Fulton County, PA
CMcAllister Offline
CMcAllister  Offline
Fulton County, PA
MORE PARTS ADDED, STATUS AND PRICES UPDATED 6/10.
360 short block. Std bore. Block, crank & rods/pistons only, still together. Rusty from sitting. Late 930 casting, 11/78 DC. $75.
X block. 2 bolt, motor mount ears ground off, 4.123" bore. Broke a rod and got into the lower edge of 2 bores. Doesn't look like it's cracked up into the bore or into water. Has been cooked, a little rusty. $900
915 J heads. Bare, 1.88 seats. not cleaned up. Some rust. $125
Late style W2 race heads. 3870810 open chamber. Appear to have not been run a whole lot. Mild porting/polishing done. Nice 2.02/1.60 SS necked down valves. 10* Ti retainers & locks. Roller springs not tested but may be fine to use. $1000
W2 heads 3670809, open chamber, ported, 2.02/1.60. Unfortunately, one of these has a large crack that runs under the exhaust ports, maybe torqued down with a too long dowel pin. $300 for one or both if you you want the cracked one.
Holley W2 Street Dominator. Good shape, but could use a good cleaning/beading. Water passage epoxyed shut. Some internal hand work. $250 SHIPPED
Weiand tunnel ram package with Edelbrock AVSs, 1405 & 1406. Std, 340/360 heads. Very nice shape. This has been installed, but I'm told not driven much if at all, and the parts look like it. They have been sitting for a while. Should clean up to look like new fairly easily. $675 SHIPPED
Prices are OBO. I really don't want to ship these blocks so pick-up in 17267 is preferred. Selling for the family of a friend who passed a number of years ago. Just trying to be fair to everyone and I know this stuff isn't mint. But it will be sold. I have some other items (blocks, heads, pieces) that I will be listing as they are checked. Pics can be emailed or texted. Just PM me.
1969 340 engine [Re: moparts] #2639536
04/01/19 09:33 AM
04/01/19 09:33 AM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
1969 340 engine
Ported & polished X heads, roller rockers, 474 MP cam
Edlebrock intake, and o.e intake included
factory exhaust manifolds
MP valve covers & air cleaner
Block cast 5621 69
2780930-340-6
Has 1 cylinder sleeved...std bores
Needs crank work
Asking $1500
PM me for more info please
Remember when cars were FUN?
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #2639546
04/01/19 09:46 AM
04/01/19 09:46 AM
Nv
Bill Koski Offline
Bill Koski  Offline
Nv
60's steel crank, std, std. $175.00
60's steel crank, rods .040 under, stroke increased .015. $105.00
Oil pump drive, $55.00
273 4-BBL Carter $75.00.
Stock valve covers $10.00 each, 1 hi-po valve cover $35.00.
273 adjustable rocker arms, $125.00.
273 connecting rods, $10.00 each, $65.00 for 8.
Distributor hold down $20.00.
Ansen steel bell housing $175.00.
Mallory electronic distributor $145.00
360 std main bearings $45.00
318, 340 main caps $40.00 set.
wirkoski@aol.com for pictures.
1970 340 long block & 1973 340 Long Block [Re: moparts] #2639922
04/01/19 10:00 PM
04/01/19 10:00 PM
MA
ragtop Offline
ragtop  Offline
MA
Both need standard rebuild and never had a rebuild. The 1970 has some rust in two cylinders in the upper portion. Will clean up completely with .020 overbore. The 1973 has slight rust in two cylinders in the upper portion. Will clean up completely with an .010 overbore. The 1970 block casting date is 6-2-69. The 1970 heads have a casting date of 10139 and 10179. The 1970 came out of a 1970 A66 Challenger 340. The 1970 is completely disassembled for your inspection. the 1973 just have the heads removed, but feel free to take off anything you want to inspect. I am selling these for my boss. They are located at his company in Merrimack NH. He has a Fork Truck with straps and a drive in loading dock to load in your vehicle. NOT SHIPPING. Both come with original timing cover and oil pan. He has telescoping gauge and micrometer for checking the bores.
1970 Long block $500
1973 Long Block $300
Re: 1970 340 long block & 1973 340 Long Block [Re: ragtop] #2640365
04/02/19 08:03 PM
04/02/19 08:03 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS MOPAR DODGE CHALLENGER T/A &PLYMOUTH AAR #2585019--CH922 PRIMARY DISTRIBUTOR LEAD.
273 and 340 dual point distributors 1967-1971
1970 340+6 AAR&TA dual point$50 mailed
paypal accepted
cowgerwilliam035@gmail.com
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #2640448
04/02/19 10:23 PM
04/02/19 10:23 PM
Metro Detroit
6PAX Offline
6PAX  Offline
Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Mr. Gasket 1" thick carb spacer. $15
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
Alternator date coded 1965. $60
Email: gt340 @ yahoo.com
Re: For Sale - Small Block Engine - 2nd Quarter [Re: 6PAX] #2640619
04/03/19 12:13 PM
04/03/19 12:13 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
nos 340-360 MP 3690866 all out race roller chain and gear set$100 plus $15 medium priority mail flat rate box shipping
paypal is accepted add 5.00 for fees
money order is accepted,sent priority mail with tracking only.
Mopar Performance timing chain and gear sets are built around high-strength, double-row roller chains, which are significantly stronger and more durable than conventional OE-type "silent" chains. In addition, Mopar Performance timing chain and gear sets reduce rotational friction versus production types. Crankshaft sprockets have three keyways to allow stock, advanced, or retarded timing. Mopar Performance timing chain and gear sets include magnafluxed sprockets and the roller timing chain.
3690866 001.JPG (1879 downloads)
3690866 002.JPG (1867 downloads)
3690866 003.JPG (1859 downloads)
3690866 004.JPG (1853 downloads)
Pan, Cam, Dipstick & Tube [Re: moparts] #2641393
04/05/19 12:04 AM
04/05/19 12:04 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
New in box Moroso #20710 8-quart pane & #24700 pick-up, with paperwork & decals, never used, 273-340 A-body cars & maybe others $230.
Crane solid FT cam & lifter set #F268-3868-2-8 aka #691561. 304/314 adv duration (268/278 @ .050) .580/.600 lift 108CL $200 for all. Xlnt/used, no problems.
New MP #P4349628 chrome dipstick & tube, still in wrapper, $30.
All + shipping.
PM me here or email topside340@yahoo.com, thanks!
SB lock roller lifters, SB pushrods [Re: moparts] #2641665
04/05/19 06:25 PM
04/05/19 06:25 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Roller lifters -
Used small block Crane roller lifters. One pair was damaged when I broke a rocker so one is a later model lifter. All roll smoothly.
$225 shipped, cont. US.
Pushrods -
New Comp ball/ball small block pushrods. Part # 7955, 7.40 length, .080 wall. $100 shipped, cont US.
Used Manton ball/cup small block pushrods, all straight. M301, 7.225 total length, .085 wall. $140 Shipped, cont US.
Roller Lifters small.jpg (1733 downloads)
Comp Pushrods.JPG (1729 downloads)
Re: SB lock roller lifters, SB pushrods [Re: shorthorse] #2642033
04/06/19 06:12 PM
04/06/19 06:12 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
340 /360 abody motor mounts. Solid and rubber included. These are from my H code Demon. $165 shipped lower 48. Postal Money order only..Pm me here.
free 318 [Re: Hot 340] #2642915
04/08/19 07:33 PM
04/08/19 07:33 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Located in ct
Hate to chuck it
Ran 15 years ago stored in a shed since.
Early to mid 70s I’m guessing
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #2643996
04/11/19 11:23 AM
04/11/19 11:23 AM
OH
Red383 Offline
Red383  Offline
OH
Cleaning out the shop:
Carb spacers $12 each + shipping
Email: 4406bbl@ g mail
call or text: nine37-six38-9two7one
Re: For Sale - Small Block Engine - 2nd Quarter [Re: Red383] #2644635
04/13/19 09:08 AM
04/13/19 09:08 AM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
like new predator solid roller it has 4 passes on it asking $250.00 neg. pm here or e-mail me @ dshellehamer@comcast.net
Custom Distributor Resto [Re: daron] #2644787
04/13/19 06:18 PM
04/13/19 06:18 PM
Pittsburgh area
BIGJOE30 Offline
BIGJOE30  Offline
Pittsburgh area
Restore and customize all Mopar distributors
Now doing Petronix or GM HEI conversion have pre drilled housings, also can adjust Vacuum Cans to what you desire for spring pressure, curb idle, and cruise to get the most out of today’s crap gas. Can set points and dwell and custom curves. Have lots of different springs to choose from.
Also when have you had your distributor bushings looked at last?? I see lots of distributors that are worn out and jump all over the place on the machine from worn weight bushings or sticking weights. Also is your dwell set right? I can set that to. Let me know what you need getting more and more cores all the time. Some pics of all the previous ones I rebuilt
Prices start at $100
Located in Eastern Ohio
Mopar Performance 360 Cast 4.0" Stroker Crank – Used [Re: BIGJOE30] #2644811
04/13/19 07:50 PM
04/13/19 07:50 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a nice used Mopar HD 4.0 stroke, 360 main, cast crankshaft part number P5007258. Crankshaft is in nice used shape and was new when installed in a bracket car. Journals are standard dimensions. Some deburring was performed on the throws and other areas as you can see in some of the photos. Drilled for 4 speed. This crankshaft was used for two seasons and have gone another direction. Crank shows some typical marking for being used. Most marks are not able to be felt with a fingernail. A couple you can ever so slightly feel it.
Price is $275 plus shipping.
Email me at procketrichard@hotmail.com for more information or pictures.
Manley 340 full groove main bearings std. [Re: Rocket] #2645389
04/15/19 01:29 PM
04/15/19 01:29 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
set of vintage Manley main bearings. Brand new full groove std. $45 plus shipping postal money order preferred
pm on board or AAcesandeights@aol.com
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #2645894
04/17/19 12:06 AM
04/17/19 12:06 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
HiPo 273 aircleaner lid, base is missing. Chrome is flaking off. No dents or dings
$80 plus shipping
Mesa, AZ
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #2645896
04/17/19 12:13 AM
04/17/19 12:13 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
1972 340 aircleaner, real nice shape.
$250 plus shipping
Mesa, AZ
Re: LA small block intake [Re: dart4forte] #2645970
04/17/19 10:10 AM
04/17/19 10:10 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
super nice, hardly used Victor 340 intake in perfect shape. fits LA, not magnum engines. It will be shipped in a correct/padded intake box as well. I can do paypal and ship it total for $275.
water neck not included. message me directly, thanks. compare to a new one here over $100 more-SUMMIT RACING LINK
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Page 1 of 4 1 2 3 4
Carlisle Photos!
by 68SportFury. 07/19/19 11:26 PM
Aluminum inspection tag orientation 71 Barracuda
by David1971. 07/19/19 10:01 PM
Original RoadRunner A12 hood WIW
by moe318. 07/19/19 09:57 PM
CONSOLE BOX "BUTTON"
by Magnumguy. 07/19/19 09:22 PM
Free standing portable AC unit experience?
by jcc. 07/19/19 05:00 PM
Moparts Recent Posts
Carlisle Photos!
by DirectSubjection. 07/20/19 12:23 AM
1961 Seneca gas tank
by demon. 07/20/19 12:21 AM
Big Block 4wd Bell Housing,
by chrisf. 07/20/19 12:14 AM
Trailer tire advice
by SomeCarGuy. 07/20/19 12:10 AM
Street strip toy!
by Iowan. 07/19/19 11:58 PM
Outrageous $$ At Carlisle
by Dragula. 07/19/19 11:51 PM
