Check your fuel lines (brand x )
#2643278
04/09/19 03:15 PM
04/09/19 03:15 PM
Posts: 34,909 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Friend , ran this car for a few years at local track .. found out , he has Twins on the way ..wife asked him to sell car .
It went to east coast somewhere and the fuel line burst at about 1/8 mile I believe , it got hurt bad .. but, driver ok
It was a Aluminum line , it split open
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Check your fuel lines (brand x )
[Re: bigdad]
#2643280
04/09/19 03:24 PM
04/09/19 03:24 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
That is a bummer to see that vehicle damaged, looks like it is a nice car. Repairable without too much trouble hopefully.
I'm not a fan of aluminum fuel line.
Whoever built the first two drag pak vehicles used that stuff. When I drove 2008001 (first prototype Drag Pak, the same one Garlits drove), I had trouble with it...it stumbled badly. Every injector was plugged with red anodizing that had come off the fuel line. It came apart and got the turbo and all that, afterwards.
Cue a poster who has used it since 1972 and never had a problem in 3.......2.......1.......:
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2643286
04/09/19 03:49 PM
04/09/19 03:49 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not me, I hate the stuff. Cheap way out that seldom works well. Even quality hose has a lifespan and won't last forever in use with fuel. The next time I see "good" hose look like a lawn sprinkler when it's pressurized after sitting for a while, won't be the first.
[Re: CMcAllister]
#2643288
04/09/19 03:54 PM
04/09/19 03:54 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I gave a whole roll away as refuse to run that crap. Between seeing results from it splitting and guys fighting fuel issues because of it kinking it’s been long gone.
[Re: pittsburghracer]
#2643306
04/09/19 04:41 PM
04/09/19 04:41 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I hate that aluminum crap and refuse to use it.
[Re: RylisPro]
#2643480
04/10/19 12:00 AM
04/10/19 12:00 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
This is why we sell Safecraft fire extinguisher systems. Fires suck! Safecraft system in my Dakota.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2643484
04/10/19 12:24 AM
04/10/19 12:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran alum line for about 1 1/2 years with zero issues but at that time I was changing from ladder bars to a 4-link so I changed my chassis and fuel system(basically build a new car but with the old body) I went with the black cloth covered line(both supply and return).. I have the same set up on my Rampage also
[Re: MR_P_BODY]
#2643518
04/10/19 07:18 AM
04/10/19 07:18 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I use and like the black cloth covered AN line. I used Fragola for %90 of my fittings and all of the hose.
68 Barracuda Formula S 340
[Re: ZIPPY]
#2643520
04/10/19 07:22 AM
04/10/19 07:22 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
GUILTY as charged.... I’d horse traded and got the Duster about a year before we moved to AZ... My dad started racing it and “upgraded” things along the way. One was a new fuel system that included aluminum line from the pump to the regulator. So yes.... about 18 years now. Since I’m hemorrhages $$$ from the wheelstand episode, maybe it’s time... the way my luck has been, better sooner than too later. ....I’m sure autozone has a roll of rubber line and some hose clamps I could score
[Re: bigdad]
#2643772
04/10/19 07:26 PM
04/10/19 07:26 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Guilty ran it for 26 yrs. Redoing the cuda but will be upgrading the entire system. It won't have aluminum this time. There are way more choices now vs early 80's and I'm not a poor college student any more.
Ok
[Re: cudatom]
#2643775
04/10/19 07:43 PM
04/10/19 07:43 PM
Posts: 614 Michigan
Get-X
I have a brand new coil of it still in the box from Mancini that came to me in a trade with a bunch of other stuff. It still sits there untouched. I have however used it in the past and haven't run into any problems, but it was always something in the back on my mind that I'd worry about.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: wyldebill]
#2645264
04/15/19 08:42 AM
04/15/19 08:42 AM
an8sec70cuda
If I'm not mistaken, isnt the cloth covered line lighter than steel braided? Yes it is. Easier to work w/ too.
[Re: moparx]
#2645951
04/17/19 08:53 AM
04/17/19 08:53 AM
Posts: 1,449 Martinsville, IN
cdwmotorsports
Martinsville, IN
My -8 Aeroquip startlite with fittings is 3.6 ounces a foot. The hose is 1.3 ounces a foot.
I have an old 6” long (hose length not including the swivels ends) stainless braided line the is 3.9 ounces.
The black line in those pics is 1” and it weighs .1 ounces an inch.
Each fitting weighs 1.3 ounces. The biggest weight loss will be eliminating connection points.
eBay-cdwmotorsports
[Re: cdwmotorsports]
#2645967
04/17/19 10:02 AM
04/17/19 10:02 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Until I get under 170 pounds I refuse to weigh fuel lines and fittings. And I’m willing to bet big money that will never happen. 😂
