Stage V engineering Hemi conversion heads
#2643101
04/09/19 08:08 AM
04/09/19 08:08 AM
Posts: 1,541 USA
hudsonhornet7x
USA
Any opinions on Stage V conversion heads? What else do you need to make them run?
Re: Stage V engineering Hemi conversion heads
[Re: hudsonhornet7x]
#2644250
04/12/19 02:23 AM
04/12/19 02:23 AM
Posts: 43,116 Bend,OR USA
Cab_Burge
Any opinions on Stage V conversion heads? What else do you need to make them run? Don't even think of doing that Every thing I've read on here about them has been bad about them
#2644265
04/12/19 03:07 AM
04/12/19 03:07 AM
Posts: 10,127 A Red State
SNK-EYZ
A Red State
There was a time when Hemi blocks weren't available so there was a need, not so much anymore.
A friend built one of the conversions back in the early 90's (he still has it).
The RB Block isn't nearly as strong in the bottom end as a true Hemi block, no cross bolted mains on a standard RB Block.
[Re: SNK-EYZ]
#2644345
04/12/19 10:33 AM
04/12/19 10:33 AM
Posts: 614 Michigan
Get-X
The RB Block isn't nearly as strong in the bottom end as a true Hemi block, no cross bolted mains on a standard RB Block. Not trying to stir the pot, but where today are Hemi blocks available that aren't $8k KB blocks or used up OE blocks for $6k+ in need of repair??
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Get-X]
#2644355
04/12/19 11:03 AM
04/12/19 11:03 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Slim pickin's out there.
But now that the supply is low, folks are cashing in and who can blame them...
This one sold yesterday (not mine)
https://www.ebay.com/itm/NEW-MOPAR-PERFORMANCE-DIRECT-CONNECTION-426-HEMI-ENGINE-BLOCK-NEW-/264270095224?item=264270095224&vxp=mtr&ViewItem=&nma=true&si=tyiY2mkj9Xkdqmp63dg2bCg8VL0%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2644363
04/12/19 11:20 AM
04/12/19 11:20 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
https://www.ebay.com/itm/NEW-MOPAR-PERFORMANCE-DIRECT-CONNECTION-426-HEMI-ENGINE-BLOCK-NEW-/264270095224?item=264270095224&vxp=mtr&ViewItem=&nma=true&si=tyiY2mkj9Xkdqmp63dg2bCg8VL0%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557 Damn. But, if it's what you "have to" have, then I guess that's the going price. Which brings us back to the OP's question about this conversion.
[Re: ZIPPY]
#2644379
04/12/19 11:43 AM
04/12/19 11:43 AM
Posts: 614 Michigan
Get-X
https://www.ebay.com/itm/NEW-MOPAR-PERFORMANCE-DIRECT-CONNECTION-426-HEMI-ENGINE-BLOCK-NEW-/264270095224?item=264270095224&vxp=mtr&ViewItem=&nma=true&si=tyiY2mkj9Xkdqmp63dg2bCg8VL0%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557 I don't blame them at all, if I had one and was selling it I would get as much for it as possible.
[Re: Get-X]
#2644507
04/12/19 07:10 PM
04/12/19 07:10 PM
Posts: 604 TN
1DGEMAN
TN
So what if you used these on a 400 block? Stronger bottom end,larger bore and if you stroked probably a lighter piston. Any thoughts?
Real Men shift for themselves
[Re: 1DGEMAN]
#2644519
04/12/19 08:21 PM
04/12/19 08:21 PM
Posts: 3,804 Arlington, Texas
bobby66
Arlington, Texas
So what if you used these on a 400 block? Stronger bottom end,larger bore and if you stroked probably a lighter piston. Any thoughts? Probably hard to find an intake for that combination.
#2645263
04/15/19 08:36 AM
04/15/19 08:36 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
The way block availability is now, I think the conversion kit is a viable option. If I was in the market, I'd definitely be looking into it.
Anyone remember Steve Magnante's (from Hot Rod magazine, B-J Auction, etc.) red hemi dart? That was a Stage V conversion on a 440 block if I'm not mistaken.
Lets be honest here...most people building a hemi aren't looking to make block breaking power. Less than 600 hp is what most seem to be after and a stock block will last a long time doing that.
[Re: RATTRAP]
#2645382
04/15/19 01:00 PM
04/15/19 01:00 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
[quote=an8sec70cuda] Why build a Hemi If your looking for 600 or less The first answer would be the guy building a hemi clone.
[Re: RATTRAP]
#2645394
04/15/19 01:46 PM
04/15/19 01:46 PM
an8sec70cuda
Lets be honest here...most people building a hemi aren't looking to make block breaking power. Less than 600 hp is what most seem to be after and a stock block will last a long time doing that. Why build a Hemi If your looking for 600 or less While I agree w/ your thinking (mine makes 4 digit HP), there are a lot of car show and cruiser guys that just want the look. Or have just always wanted a hemi. Back when they were available, I bet the "little" 465 hp crate hemis outsold the 600+ hp 528" crates 10 to one.
