Re: Anyone running aluminum heads with a 6 pack
[Re: dogdays]
#2642569
04/08/19 03:21 AM
04/08/19 03:21 AM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Yes,you will be pleased with the upgrade. Use something with a ""stock"port window.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2642573
04/08/19 04:37 AM
04/08/19 04:37 AM
Posts: 1,747 PA
plumcrazycuda
PA
Ok what my bestest bang for my buck?
[Re: plumcrazycuda]
#2642622
04/08/19 09:04 AM
04/08/19 09:04 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
running al heads is no big deal. I have built several all ready but my question is what is your combo that you have now that keeps blowing head gaskets. without finding what your problem is you may still have the same problem.
JAKES AUTOMOTIVE
[Re: plumcrazycuda]
#2642724
04/08/19 12:49 PM
04/08/19 12:49 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I did the swap on my old pump gas Duster 505 C.I. low deck six pack pump gas motor from a set of ported and polished big valve 906 to a set of CNC ported Eddy RPM, that car picked up a solid two tenths and 3 MPH in the 1/4 with the exact same compression ratio. I change the crank stroke by .050 (4.250 to 4.300)the next winter to go from 9.25 to 1 to 10.29 to 1 compression and that picked up the car some more On your deal go with some good heads like the Eddy RPM with the 84.0 CC combustion chambers or the other set with the smaller 75.0 CC chambers, do the math on which heads give you which compression ratio, I wouldn't go above 10.75 to 1 or higher on todays pump gas IHThs, six packs rock
[Re: sogtx]
#2643046
04/08/19 11:51 PM
04/08/19 11:51 PM
Posts: 614 Michigan
Get-X
Jeesh No trick flow praises? Did i miss any shortcomings ? This was mine with sick pack Six packs do Rock ! My stroker build Yep, I'd be headed right for the TF 240s
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: sogtx]
#2643072
04/09/19 03:10 AM
04/09/19 03:10 AM
Cab_Burge
Jeesh No trick flow praises? Did i miss any shortcomings ? Six packs do Rock ! My stroker build I haven't used any of the Trick Flow heads yet so no hands on experience hence no comments on them either way by me I'm looking forward to building a pump gas 400 stroker motor in the near future with a set of the Trick Flow 270, if the potential customer wants over 650 HP on pump gas If not it will get a set of Trick Flow 240
