4.7 to 5.9 transplant #2640902
04/03/19 09:08 PM
04/03/19 09:08 PM
Western Colorado High Desert
moparmarks Offline OP
Looking at some 2000-2004 Dakotas with the 4.7. What all is needed to change to a 5.9 ?
Looking for a 5-spd but also interested in the interchange with a auto too.
Many thanks
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 4.7 to 5.9 transplant [Re: moparmarks] #2641151
04/04/19 12:38 PM
04/04/19 12:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
trans, wiring harness, computer, motor mounts and a whole pile of small parts are different, you could get a harness and computer from a 318 truck to use the manual trans, they do bolt up but since the 5.9 never got the 5 speed there is no computer made for it, another option would be the 5.9 computer from a 3/4 or one ton but they had extra 02s so you would need to add them to keep off the CEL. The 4.7 flywheel will only work if it has the notches for the crank sensor to read. Whatever you get you pretty much need the exact year matching trucks for donors as the body computers and such need to match. I guess what it all boils down to is finding two trucks with the same computer systems and a 3rd heavy doody truck for the actual computer.
Re: 4.7 to 5.9 transplant [Re: HotRodDave] #2641236
04/04/19 04:43 PM
04/04/19 04:43 PM
Thanks for the info.
Couldn't you get a 5-spd with the 5.9 in a 4x4?
I'm looking at a decent 4x4 with an automatic and a blown 4.7.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 4.7 to 5.9 transplant [Re: moparmarks] #2641274
04/04/19 06:46 PM
04/04/19 06:46 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i heard a 5.7 is an easier swap for a 4.7-----wire loom plugins the same----but i havent done one.....also putting in a 5 speed manual over an RE tranny not that bad....
Re: 4.7 to 5.9 transplant [Re: savoy64] #2641979
04/06/19 01:43 PM
04/06/19 01:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
no 5.9 5 speed in a 1/2 ton or dakota, the factory didn't trust the nv3500 behind a 5.9 and the nv4500 was too clunky and truck like for the people who want a truck for a car.
