Re: Budget bracket duster build?
[Re: AndyF]
#2642798
04/08/19 03:21 PM
04/08/19 03:21 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of you guys are over-thinking this racing game. Keep it simple and on a budget and go have FUN. My kids stock cast crank runs 6.54 at 3200 pounds (10.20's-10.30's) and with an alternator, alcohol fuel, (165.00 for 54 gallons) he charges the battery once a month because cooling isn't needed at all in the pits. Frame connectors, caltracks, stock wheel-wells, 4.10 gears 8 3/4 rearend, 727 transmission, 750 alcohol carb done by APD, 11-1 comp, small 620 lift roller cam, Edelbrock heads and Victor intake I ported, 1 7/8 Hedmen headers, and 6 point cage, and the only fiberglass is a heavy 6 pak hood. Heck it still has the rear seat and a stock passenger side bucket seat (race seat for driver. Don't let guys BS you and say about all the EXTRA work running alcohol. Pull the seats on his car, fiberglass bumpers, aluminum bumper brackets and he's 10's. Don't over-think it.
[Re: pittsburghracer]
#2642812
04/08/19 04:01 PM
04/08/19 04:01 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This is not mine but kinda shows you how cheap it can be done. More pictures on the link. https://www.facebook.com/groups/MoparDragRacing/1971 Duster Street/Strip Roller for trade $5,500 23061 Looking to trade for 68-72 B Body or 67-72 Dart roller with title.. 1971 Plymouth Duster, No motor or trans. Clean and clear title in my name. Was on the street a month ago pulled motor to freshen and decided to find something with a backseat for kids. Car is Mini Tubbed with narrowed 8 3/4, A.R.T Ladder bars and Strange Single Adjustable coilovers. (Could still go back to leaf springs, Inboard boxes and stock frames rails still in place.) 8 point Roll bar and frame connectors. 8 3/4 has 4.10s and spool. Drum brakes in rear, Wilwood disc in front, aluminum manual master cylinder with line lock. Brand new Pro Stars and tires. 15x10 with 275/60 ET street. Will hold a 12in wheel. 10 Gal. Fuel cell, Holley blue pump, 1/2 aluminum fuel line and 3/8 aluminum return ran. Body is in good shape, painted with Eastwood satin black, does have a patch in Right rear lower quarter and little filler, and driver floor pan been replaced. Nice AAR fiberglass 6 pack hood. Interior could use some TLC, factory panels, carpet etc. car comes with factory bench seat, no heater box. Car had small block and 904 trans. Will come with some hooker headers, radiator and drive shaft. All lights and wiper work. Looking to trade for roller in same shape to drop my motor and trans in. Or will sale for $5500 any questions pm me. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr
#2642826
04/08/19 04:27 PM
04/08/19 04:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I agree with Pitts.. dont over think it. the 2 things I did was to make my car lighter and I ran E-85.. around here I could buy it at most of the stations around here so it was cheap and easy to get.. I ended up running 8.90s with a SB.. 9.5 is when you had to have the NHRA cert from a doctor.. I played that game with the NHRA but I had some other medical issues also so I couldnt get a license the last time
#2642841
04/08/19 04:44 PM
04/08/19 04:44 PM
Posts: 369 Bowler Wisconsin
Smoparmike
Bowler Wisconsin
I want to have fun and go rounds. 10.0 isn't a must have but everyone always wants to go as fast as possible. I have my 64 for messing around. I have the complete drive line that I had in 64 radiator, alt, pulleys,etc from 64 it ran 11 teens @3700lb. with a best of 10.88. I built a maxwedge cloneish. With new radiator alt, pulleys, distributor, ignition, motor with crossram new convertor, trans. The biggest things are chassis, brakes, suspension, roll bar. I'm planning on doing work myself with help from a couple buddies. Body and paint are not a big priority. Most likely flat black or something like single stage enamel. Pittsburghracer that duster looks like a hell of a deal. If I was wanting to go racing now that would be what I would be looking for. I'm still sorting out the 64 and that motor build was in 2016 so I don't do anything to fast. I'm hoping life will slow down in a few years. If not my kids will have a bunch of stuff to sell
[Re: Smoparmike]
#2642863
04/08/19 05:26 PM
04/08/19 05:26 PM
MR_P_BODY
I have always been a chassis guy and didnt bother a lot about making big power.. I would tell you to make your ladder bars a bit longer longer than the standard kit ones.. I went both ways on my stuff.. the 4-link is the way to go.. way more adjust ability to them
[Re: Smoparmike]
#2642912
04/08/19 07:15 PM
04/08/19 07:15 PM
Posts: 31,037 Oregon
AndyF
Mr. P I agree with you lighter is better faster and easier on parts. The couple of cars I have raced were always a compromise between race car and street car. I like the idea of E85. It is available here, but I'm a ways away from deciding that. E85 or not is a good thing to think about. Personally I wouldn't go that way but perhaps it would work for you. If it was my car I'd set the engine up to run pump gas and then I'd use a Holley Sniper on there. The Sniper will tune itself for changes in elevation or weather so that is one less thing for you to worry about in the pits. Pump gas is cheap and easy to find and the O2 sensor will last a long time. If the car weighs 3000 lbs you only need 600 hp to run low 10's and that is easy to do with a pump gas big block. A set of Trick Flow heads and a mild street roller cam should get you into the 600 range with a Trick Flow intake and a 800 cfm Sniper. That should be a very solid and reliable combo that could go rounds for a lot of races. The Sniper also gives you a built in data logger which is nice.
[Re: Smoparmike]
#2642984
04/08/19 09:39 PM
04/08/19 09:39 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My 2 cents. Make the car easy to work on, and low maintance. Build it so it can hot lap if you have to.
A car that repeats and prints time slips is a lot easier to win with than one that has wild ET swings because of a little DA change or some track starting line inconsistency
Go to your local track and get involved with what ever you have that runs, and get ideas for what you really want to build.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2642996
04/08/19 10:05 PM
04/08/19 10:05 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
The definition of bracket racing people that spend a whole bunch of money to make junk Go real fast and then slow it down so they don't go too fast ... not sure I quite understand the concept
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2642999
04/08/19 10:14 PM
04/08/19 10:14 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The definition of bracket racing people that spend a whole bunch of money to make junk Go real fast and then slow it down so they don't go too fast ... not sure I quite understand the concept Most of us don’t play that game
[Re: WHITEDART]
#2643042
04/08/19 11:47 PM
04/08/19 11:47 PM
Just-a-dart
Glendora Ca.
The definition of bracket racing people that spend a whole bunch of money to make junk Go real fast and then slow it down so they don't go too fast ... not sure I quite understand the concept Well sir some of us don't want to shove a lit JATO rocket into our butt and fly to the finish line while torching our wallet, we prefer a gentlemans game of chess at a 125+mph
[Re: WHITEDART]
#2643092
04/09/19 07:23 AM
04/09/19 07:23 AM
Posts: 570 UK
rb446
UK
The definition of bracket racing people that spend a whole bunch of money to make junk Go real fast and then slow it down so they don't go too fast ... not sure I quite understand the concept You'd love watching racing over here then ....thats mostly all we do, brkts and 8 sec cars running SG, etc.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Smoparmike]
#2643266
04/09/19 02:35 PM
04/09/19 02:35 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I started racing at a track in SO CA in 1964 when class racing was the only choice at Mickey Thompson Fontana Drag City I remember when bracket racing started a little later and thought that was a bunch of bunk I didn't do any more at the track racing until around 1972 and not many of the tracks in SO CA had a regular schedule class racing races, but they all had regular bracket races every weekend and some of them race during the week also My message is if I didn't learn to bracket race I could only race class 5 or 6 times a year We all get to make choices in life, my choices on drag racing are now limited by the market place
