Brake Drum Size #2641582
04/05/19 01:51 PM
04/05/19 01:51 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9 2WD. I can see #41061 on the drums. Are those 9" or 10"?
Grandma always said I had "hands of gold"!
Re: Brake Drum Size [Re: CHRGR69] #2641589
04/05/19 02:20 PM
04/05/19 02:20 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Got a tape measure?
I have mechanical Aptitude.
I can screw up anything.
Re: Brake Drum Size [Re: bboogieart] #2641599
04/05/19 02:45 PM
04/05/19 02:45 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Peeking through the rims. Plenty of tape measures, just not ready to pull the wheel.
Re: Brake Drum Size [Re: CHRGR69] #2641768
04/05/19 10:05 PM
04/05/19 10:05 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Use your tape to measure the amount of backing plate that fits inside the drum from under the truck. It could have come with either a the 9" or the 10" brakes, a measurement across the backing plate should get you close enough to make a call. Gene
