Carb stumble #2641036
04/04/19 08:18 AM
04/04/19 08:18 AM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Looking for some help. I have a small block 360 drag race motor. After adding aluminum heads last season, there was a small stumble if you try to jab the throttle from idle. I footbrake race, and when I bring the car into stage I'm at 2500 rpm. It has never stumbled when on track. It only happens from idle. Timing is at 36 degrees. I tried 38 as well, but no change. Primary squirter is 35. I tried both up and down and no change. Power Valves are blocked and jets are at 76. It runs as smooth as can be other than when I jab the throttle at idle. Starting to get frustrating so looking for any ideas/suggestions to try. Thank you in advance!
Re: Carb stumble [Re: scarly10] #2641059
04/04/19 09:17 AM
04/04/19 09:17 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Master, again and still
Re: Carb stumble [Re: scarly10] #2641067
04/04/19 09:35 AM
04/04/19 09:35 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You got a good link on the video follow those directions. One other thing, when you stab the throttle, the spring on the pump linkage compresses so you don't bend the linkage. So in reality the strength of that spring controls a lot of how much and how long of a pump shot you get. If you stack a couple small washers under the spring you will make it stiffer, making sure you get a strong pump shot. Don't get carried away because if you make it too strong you can bend the linkage. But I have fixed several new out of the box carbs that had too weak of a spring this way.
Re: Carb stumble [Re: scarly10] #2641163
04/04/19 01:09 PM
04/04/19 01:09 PM
Does the exhaust stink when warmed up at idle? If so you need to lean down the idle mixture to help it not bog.
If it doesn't stink try enrichening the idle mixture screws a 1/4 turn at a time to see if that helps get rid of the stumble scope thumbs
You can make a carb stumble off idle by being to lean or to rich whiney shruggy
Do your squirters squirt fuel as soon as you move the throttle shafts any at all? If not adjust the screw so it does up
What brand and size is the carb?
Re: Carb stumble [Re: Cab_Burge] #2641173
04/04/19 01:42 PM
04/04/19 01:42 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
It doesn't seem to smell, so maybe I will try enrichening the idle mixture. The squirters work as they should. I've checked that over. It's a Holley....double pumper....750 cfm.....4150 series.
Re: Carb stumble [Re: scarly10] #2641192
04/04/19 02:48 PM
04/04/19 02:48 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
when you say work as the should, do you mean, basically as soon as you breath on the throttle lever you see a shot of fuel from the squirters?
I've revisit the idle mix, fully warmed, lean out to highest idle, then go about 1/16-1/8 turn richer all around, after those two things...i would maybe look at pump cams.
Re: Carb stumble [Re: krautrock] #2641197
04/04/19 03:00 PM
04/04/19 03:00 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Yes. As soon as it's touch it's squirting. That's the first thing I checked. I think I'll do the idle mix first like you say. Then if it's not fixed, I'll have to keep searching
Re: Carb stumble [Re: scarly10] #2641267
04/04/19 06:28 PM
04/04/19 06:28 PM
Does it still have the stock undrilled throttle plates in it?
Is it a four corner idle unit or the front only type? If four corner adjust all of them, if not do what you can thumbs
If no extra holes in the throttle plates try the idle mixture screws and make sure the rear throttle shafts are not opened a bunch scope
Re: Carb stumble [Re: Cab_Burge] #2641278
04/04/19 07:00 PM
04/04/19 07:00 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I would suggest a wide band so; you can determine exactly what the car is doing and go from there.
Re: Carb stumble [Re: parksr5] #2641326
04/04/19 09:05 PM
04/04/19 09:05 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Blue cam on 30cc or put 50cc pump on it.
Re: Carb stumble [Re: scarly10] #2641328
04/04/19 09:13 PM
04/04/19 09:13 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
You indicated it's a double pumper. Did you careful check the secondary accelerator pump behavior as well as the primary?
Re: Carb stumble [Re: davenc] #2641407
04/05/19 01:39 AM
04/05/19 01:39 AM
CA
crackedback Offline
crackedback  Offline
CA
Is the timing locked at 36 or is that the total number?
Re: Carb stumble [Re: crackedback] #2641423
04/05/19 06:01 AM
04/05/19 06:01 AM
UK
rb446 Offline
rb446  Offline
UK
"Blue cam on 30cc or put 50cc pump on it"
^^^^^this
We never had any hesitation issues on either the 750 or later the 850DP carbs we ran on my 340 car. However in an effort to make things even better with what we had we put a 50cc pump on the 850 and noticed a good improvement even on the street when testing, it had the desired effect at the track on the hit f/braking, and that carb was almost 2/10ths quicker in the 1/4 than the 750DP the car came with so a good gain for not a lot of money, just glad I used to think out of the box as everyone else at the time said that was too big of a carb for a small motor.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Carb stumble [Re: crackedback] #2641430
04/05/19 07:14 AM
04/05/19 07:14 AM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Not locked. Initial is 21. Total 36. Locking out the distributor is something I’ve considered.
Re: Carb stumble [Re: scarly10] #2641457
04/05/19 09:04 AM
04/05/19 09:04 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Check the SECONDARY A/P adjustment
Re: Carb stumble [Re: GTX MATT] #2641459
04/05/19 09:06 AM
04/05/19 09:06 AM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
same clearance on the secondary AP as the primary AP? I'm at 15 thousandths at WOT
Re: Carb stumble [Re: scarly10] #2641472
04/05/19 09:45 AM
04/05/19 09:45 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Get a spray bottle and put gas in it. Have a buddy (that you trust) stab the throttle On the brake, to the point where it stumbles. be ready and give it a spray from the bottle. If it's better you know what to do, if it's worse you also know what gives. I know it's redneck, but saves hours of playing around trying this that or the other. Done it on the dyno, and in the car, most times with the trans brake.
Also if it's 3 circuit, try tooth picks in the intermediate air bleed to block them off. If that is worse, just remove the intermediate air bleed, and try again.
Obviously goal being just to know whether you need fuel there, or have too much.
Re: Carb stumble [Re: scarly10] #2641703
04/05/19 08:09 PM
04/05/19 08:09 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Motor off, slowly open throttle to WOT and observe when the secondary shooter discharges relative to secondary throttle plate opening. Poor relationship can lead to a lean or over-rich spot; increasing primary pump discharge can cover up lean spot, or changing secondary cam or cam position to fix timing can fix lean or rich..
Re: Carb stumble [Re: davenc] #2641795
04/05/19 11:39 PM
04/05/19 11:39 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
check the vacuum at idle and reinstall the correct the pri power valve .
this will add fuel before main jet and eliminate bog.
Re: Carb stumble [Re: calrobb2000] #2641801
04/06/19 12:16 AM
04/06/19 12:16 AM
Washington
madscientist Offline
Washington
Originally Posted by calrobb2000
hi
You do not set power valve opening by idle vacuum. That is incorrect.
