Re: Carb stumble [Re: calrobb2000] #2641864
04/06/19 08:47 AM
04/06/19 08:47 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Originally Posted by calrobb2000
hi
check the vacuum at idle and reinstall the correct the pri power valve .
this will add fuel before main jet and eliminate bog.
In addition to the fact that you don't set the power valve opening by the idle vac, the power valve is part of the main circuit. So it can't add fuel before the main circuit. Unless, of course it's blown.
Master, again and still
Re: Carb stumble [Re: DaveRS23] #2641951
04/06/19 12:46 PM
04/06/19 12:46 PM
I've seen some guys have the idle speed adjusted so high it is idling on the transition and mains circuits instead of only on the idle circuits realcrazy shruggy
