replace hinge pins without removing door #2639480
04/01/19 06:31 AM
04/01/19 06:31 AM
MD
rich006 Offline OP
rich006  Offline OP
MD
Is it possible to get the upper hinge pin out without taking the door off the hinge first? I don't think so, but I haven't seen anyone talking about removing the door from the hinge before replacing the pin.
Re: replace hinge pins without removing door [Re: rich006] #2639629
04/01/19 12:25 PM
04/01/19 12:25 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
What vehicle ?
Re: replace hinge pins without removing door [Re: rich006] #2639633
04/01/19 12:27 PM
04/01/19 12:27 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Did it on my 77 van.
Knocked the old pin out with a punch and hammer.
Top first, then the bottom hinge.
I did support the door with a board and a floor jack.
I have mechanical Aptitude.
I can screw up anything.
Re: replace hinge pins without removing door [Re: 135sohc] #2639709
04/01/19 02:34 PM
04/01/19 02:34 PM
MD
rich006 Offline OP
rich006  Offline OP
MD
It’s a 1989 D100. The door panel curves inward above the upper hinge so it seems impossible to get the pin in or out.
Re: replace hinge pins without removing door [Re: rich006] #2640160
04/02/19 11:58 AM
04/02/19 11:58 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Might it be easier to remove the panel than the entire door?
Re: replace hinge pins without removing door [Re: rich006] #2640170
04/02/19 12:17 PM
04/02/19 12:17 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I did mine with the doors removed. They were coming off anyways for other reasons but yeah it is tight up there.
Re: replace hinge pins without removing door [Re: bboogieart] #2640196
04/02/19 01:01 PM
04/02/19 01:01 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Not positive but I believe he's talking about the outer door skin curving in over the hinge making it hard to get the pin in the top of the hinge.
Re: replace hinge pins without removing door [Re: Jwilli500] #2640203
04/02/19 01:12 PM
04/02/19 01:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Didn't think of that.
Might just be easier to remove the door.
Get a friend to help, beer then it's not that bad.
Re: replace hinge pins without removing door [Re: Jwilli500] #2640905
04/03/19 09:11 PM
04/03/19 09:11 PM
MD
rich006 Offline OP
rich006  Offline OP
MD
Yes, that's what I was talking about. I may have used the wrong words. I've already done one door but the other one only needs the top hinge replaced. I'd like to replace only the top hinge without removing anything else, but I don't know if it's possible. It sure doesn't look possible.
Re: replace hinge pins without removing door [Re: rich006] #2660131
05/28/19 08:03 PM
05/28/19 08:03 PM
Maryland
regularjay Offline
regularjay  Offline
Maryland
I did just the bottom hinge on my 92 a couple weeks ago, Didn't want to deal with disconnecting the power windows & locks - really wasn't too hard. I did support the door during the process.
79 Lil Red Express - I'll finish it someday
94 2wd Ram 1500 5.9 Donor for...???
78 CJ7 4.2 with Clifford Cam, Holley 390, 4" on 33's
1992 W250 Cummins
2013 Ram 4X4 Hemi Crew Express
2005 Ex Cab Dakota 4x4 4.7 Daily Driver
1993 2wd Ramcharger 5.2/auto
Re: replace hinge pins without removing door [Re: regularjay] #2660134
05/28/19 08:12 PM
05/28/19 08:12 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
would it possible to take the upper hinge off the door-----with the door supported by a cherry picker----lean it away a couple inches---change out the pin?
Re: replace hinge pins without removing door [Re: savoy64] #2660643
05/30/19 03:10 PM
05/30/19 03:10 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I like that idea. up
If it's like my '76, one bolt accessed from the out side and two from the inside, under the dash.
Would take a lot of patients,.
Not my strong point. mad
The are only two bolts going into the door.
Leaving the bottom hinge attached should help with re-alignment.
