Re: Signs of excessive or abnormal bronze gear wear?
[Re: BradH]
#2639661
04/01/19 12:59 PM
04/01/19 12:59 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A good idea is to make note of the slack (movement) between the drive gear and the cam when new. Then it's easy to detect wear if the thing is getting sloppy, by popping the distributor and checking with a large screwdriver or tool.
Or visually compare used to a new one.
[Re: BradH]
#2639680
04/01/19 01:23 PM
04/01/19 01:23 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Sure!
Well, we can try.
Post away.
Rich H.
Esse Quam Videri
[Re: BradH]
#2639792
04/01/19 06:28 PM
04/01/19 06:28 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I always compare the gear wear to the inside most area of the teeth. I noticed some weird gear wear on my small block on this last inspection and when I put it in the block to check how much slop it had it turns out the bushing in the block was shot. It hadn't been in very long but it was very worn so I changed it and put another gear I had in. I have always just dropped the gear in and never checked that bushing, I am glad I noticed it before it chewed up another gear.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2639822
04/01/19 07:26 PM
04/01/19 07:26 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Brad your oil filter will tell you a lot about what is happening to that brass gear.
"Just a Bracket car dressed up like a streetcar"
[Re: Bad340fish]
#2639826
04/01/19 07:31 PM
04/01/19 07:31 PM
Posts: 3,916 usa
lewtot184
usa
I always compare the gear wear to the inside most area of the teeth. I noticed some weird gear wear on my small block on this last inspection and when I put it in the block to check how much slop it had it turns out the bushing in the block was shot. It hadn't been in very long but it was very worn so I changed it and put another gear I had in. I have always just dropped the gear in and never checked that bushing, I am glad I noticed it before it chewed up another gear. bushings can be a big issue. I've got a bunch of new ones that are too loose to use.
[Re: lewtot184]
#2639828
04/01/19 07:36 PM
04/01/19 07:36 PM
Posts: 4,669 Wichita
GY3
Wichita
Silly question: Why are you using a bronze gear in a street car instead of the melonized gear?
[Re: BradH]
#2639972
04/01/19 11:12 PM
04/01/19 11:12 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I had a camshaft that would mow right through the gears I actually ended up taking some sandpaper and rounding the edges of the gear on the cam.. man night and day difference
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2639991
04/01/19 11:59 PM
04/01/19 11:59 PM
BradH
In no particular order...
I have an oil filter cutting tool, but need to locate it after things got stuffed "wherever" when we had to deal with a basement plumbing leak last year.
I feel no detectable looseness between the bronze gear and the cam gear. I do think that I can push the oil pump drive shaft forward & backward maybe. 015" +/- due to bushing wear.
Dwayne Porter and I spoke about the melonized gear option a couple years ago when I was collecting parts. I run a high-volume oil pump, and the open spring loads with the new roller cam are about 600#s. If something about my combination does result in excessive wear on the treated steel gear, that's going to put more dangerous sh!t in my engine than the softer bronze gear, so I took his advice and decided to play it safe at this time.
We also talked about the possibility of sharp edges on the cam gear causing wear, which is why I used a small wire brush with a Dremel on the cam gear before installation. Not sure if it would have been better to use a small grinding stone and bevel the edges of the teeth, though.
I took a number of pictures tonight. However, the image sizes may be too large to upload directly from my phone. If they're too big, I'll have to shrink 'em some on my laptop and attach them tomorrow.
[Re: BradH]
#2639994
04/02/19 12:06 AM
04/02/19 12:06 AM
BradH
View of gear & cam before removing oil pump drive.
[Re: BradH]
#2639995
04/02/19 12:09 AM
04/02/19 12:09 AM
BradH
Contact pattern on bronze gear visible...
