Re: Proportioning Valve
[Re: 70charger512]
#2639732
04/01/19 03:37 PM
04/01/19 03:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A while lot more info is needed than what you have provided and the answer would still be, maybe.
I would plumb one in, but I have 13 letters in my last name.
[Re: Jerry]
#2640080
04/02/19 09:03 AM
04/02/19 09:03 AM
Supercuda
About to go away
About to go away
up yours
The OEM's spent a lot of time and money dialing in brake systems and figuring proportioning valve specs only to get it wrong (A bodies come to mind).
You're likely to get real close but find that the last little bit is off and an adjustable setup can let you dial it in right.
[Re: 70charger512]
#2641508
04/05/19 11:12 AM
04/05/19 11:12 AM
Posts: 30,993 Oregon
AndyF
It all depends on how hard you are going to drive the car. Road race guys tweak the prop valve during the race as the fuel tank gets lighter. Most grocery getters have no idea what a prop valve is. Just depends on which end of the curve you are. When we did Tim's Valiant the prop valve was under the floor with the knob under the driver seat so Tim could adjust it while driving. That was a pretty hardcore setup though.
[Re: AndyF]
#2641517
04/05/19 11:30 AM
04/05/19 11:30 AM
Supercuda
About to go away
About to go away
up yours
This being the handling forum I tend to think questions here are going to be more hard driving type than grocery getter type.
So I answer them with that thought in mind. Had this been the Q&A forum I probably would not have answered it the same.
