wiper motor rubber bushings w/ metal insert #2635729
03/22/19 10:51 PM
03/22/19 10:51 PM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
Does anyone reproduce the wiper motor mounting bushings with the metal insert? Mine are dried out and the metal insert is pretty corroded and I'd like to replace them all. So far, I haven't found anyone and the ones in the HELP section at auto parts stores do not have the correct opening size for the stud to fit through.
inherited a 69 roadrunner from my grand pop.
Re: wiper motor rubber bushings w/ metal insert [Re: fuelishnsilly] #2635799
03/23/19 08:31 AM
03/23/19 08:31 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you look closely you'll see that those bushings were installed and "crimped" after the rubber insulator. You can't get one out without wrecking the bushing or insulator. My guess is for that reason nobody has yet reproduced them. The closest thing you'll find will be a poor knock-off from SF Restoration (a sponsor here). They fit both the insulator and the stud but they don't look correct.
Re: wiper motor rubber bushings w/ metal insert [Re: Stanton] #2635810
03/23/19 08:52 AM
03/23/19 08:52 AM
md
mopars4ever Offline
mopars4ever  Offline
md
two speed bushings should be 2932708 You can find them on ebay from time to time.
Re: wiper motor rubber bushings w/ metal insert [Re: mopars4ever] #2635984
03/23/19 04:04 PM
03/23/19 04:04 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I have some of each 2 and 3sp
PM here
NS1AAR
Re: wiper motor rubber bushings w/ metal insert [Re: ns1aar] #2636044
03/23/19 05:39 PM
03/23/19 05:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: wiper motor rubber bushings w/ metal insert [Re: Stanton] #2636051
03/23/19 05:44 PM
03/23/19 05:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
$ 1.42 Canadian from Rock Auto.
Re: wiper motor rubber bushings w/ metal insert [Re: Stanton] #2636145
03/23/19 09:29 PM
03/23/19 09:29 PM
Greenwood Lake, NY
Greenwood Lake, NY
I tried the Dorman HELP ones and the opening diameter for the stud is not big enough.
Re: wiper motor rubber bushings w/ metal insert [Re: fuelishnsilly] #2636292
03/24/19 10:11 AM
03/24/19 10:11 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Bill has what you need !
https://www.bmcuda.com
Re: wiper motor rubber bushings w/ metal insert [Re: 62maxwgn] #2636318
03/24/19 10:46 AM
03/24/19 10:46 AM
moparx Offline
moparx  Offline
for some reason [probably me biggrin], i always seem to have a time getting those type of bushings in place when they are new, unless they have a two piece metal sleeve/insert. or are those a two piece deal ?
beer
Re: wiper motor rubber bushings w/ metal insert [Re: 62maxwgn] #2636639
03/24/19 09:03 PM
03/24/19 09:03 PM
Greenwood Lake, NY
Greenwood Lake, NY
I checked out the ones at Bill Meerholz site. I see the rubber bushing but I did not see the metal insert. Did the 3 speed wiper motors get that metal insert or does my factory wiper motor have some added metal sleeve for some reason?
Re: wiper motor rubber bushings w/ metal insert [Re: fuelishnsilly] #2637045
03/25/19 04:57 PM
03/25/19 04:57 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Hi Fuel....
These are the usual cowl seal you would find on a 3 speed wiper motor 66 -74
Re: wiper motor rubber bushings w/ metal insert [Re: ACR2000] #2637373
03/26/19 01:56 PM
03/26/19 01:56 PM
Greenwood Lake, NY
Greenwood Lake, NY
my gasket looked like the one on the right. Whats left of the bushings also look like the ones on the right but the insert looked more like the left but extremely corroded away.
Re: wiper motor rubber bushings w/ metal insert [Re: fuelishnsilly] #2638750
03/30/19 10:00 AM
03/30/19 10:00 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
I am having some made, should get them in a few weeks
Re: wiper motor rubber bushings w/ metal insert [Re: ACR2000] #2643559
04/10/19 09:40 AM
04/10/19 09:40 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I actually have one 2932708 kit. PM me
