LCA rubber bushings #2637899
03/27/19 10:11 PM
03/27/19 10:11 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
I'm in the middle of taking apart the front suspension and is wondering what everyone has to say: PST says to reuse the LCA inner shell with their pivot shafts, but is the inner shell not already in this bushing? Or is there another shell that goes into this?
Re: LCA rubber bushings [Re: 70charger512] #2637938
03/28/19 12:34 AM
03/28/19 12:34 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
I can clearly see it , it is bonded to the rubber .
Re: LCA rubber bushings [Re: pro451bee] #2637999
03/28/19 09:53 AM
03/28/19 09:53 AM
moparx Offline
moparx  Offline
inner shell, bushing, outer shell. all bonded together. is that their replacement ?
beer
Re: LCA rubber bushings [Re: moparx] #2638002
03/28/19 10:01 AM
03/28/19 10:01 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Yep this is PST's bushing, from what I've heard, usually you would want to press the pivot shaft into the inner shell before it goes into the rubber. I've heard if you press the inner shell into the rubber first, the pivot shaft usually pushes the inner shell out of the rubber. So has anyone had a problem pressing the pivot shaft into PST's bushings?
Re: LCA rubber bushings [Re: 70charger512] #2638013
03/28/19 10:28 AM
03/28/19 10:28 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
that's just a regular rubber bushing. you need to get the outer shell out of the control arm and the inner shell off the pivot shaft before you press the new one in.
Re: LCA rubber bushings [Re: 70charger512] #2638103
03/28/19 01:52 PM
03/28/19 01:52 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
So i grabbed the pivot shaft, and correct me if im wrong, but there isnt a sleeve on it. So either its somehow stuck in the bushing, or Im right about the PST bushing coming with the inner shell. Right?
Re: LCA rubber bushings [Re: 70charger512] #2638128
03/28/19 03:16 PM
03/28/19 03:16 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
is that a factory chrysler pivot shaft? if so, then the bushing is ready to press onto that shaft.
I can't comment on aftermarket pivout shafts as I have not used them..
Re: LCA rubber bushings [Re: krautrock] #2638410
03/29/19 09:32 AM
03/29/19 09:32 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Yes it is factory, so what you're saying is the sleeve that goes on the pivot shaft is already in the bushing correct?
Re: LCA rubber bushings [Re: 70charger512] #2638621
03/29/19 09:36 PM
03/29/19 09:36 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Correct. When the old bushings get pressed out, generally the Inner bushing shell stays on the pivot shaft and the outer shell usually remains in the control arm.
Re: LCA rubber bushings [Re: 70charger512] #2639060
03/31/19 05:39 AM
03/31/19 05:39 AM
Australia
dodgy Offline
dodgy  Offline
Australia
this video clip may help explain how it all works
https://youtu.be/iJaKDd7p85w
