Holley 6193 idle help needed *fixed* #2637710
03/27/19 01:10 PM
03/27/19 01:10 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
a
Re: Holley 6193 idle help needed [Re: RJS] #2637711
03/27/19 01:12 PM
03/27/19 01:12 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
o
Re: Holley 6193 idle help needed [Re: RJS] #2637753
03/27/19 02:48 PM
03/27/19 02:48 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You said it cleaned up when you covered the idle bleeds. It has a vacuum leak. If you take away air and it runs clean, it is sucking air from where it's not supposed to.
Re: Holley 6193 idle help needed [Re: Dave Hall] #2637757
03/27/19 02:56 PM
03/27/19 02:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That can also be a sign of being excessively lean .
Re: Holley 6193 idle help needed [Re: Dave Hall] #2637779
03/27/19 03:57 PM
03/27/19 03:57 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
d
Re: Holley 6193 idle help needed [Re: 62maxwgn] #2637783
03/27/19 03:59 PM
03/27/19 03:59 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
d
Re: Holley 6193 idle help needed [Re: RJS] #2637804
03/27/19 05:23 PM
03/27/19 05:23 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I
Re: Holley 6193 idle help needed [Re: RJS] #2637824
03/27/19 06:40 PM
03/27/19 06:40 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Fatten it up! See what happens?
Re: Holley 6193 idle help needed [Re: Dave Hall] #2637845
03/27/19 07:30 PM
03/27/19 07:30 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
d
Re: Holley 6193 idle help needed [Re: RJS] #2637881
03/27/19 09:16 PM
03/27/19 09:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
So how do you suppose "I fatten it up?"
How do you fatten the idle circuit on this carburetor?
Ron
Idle feed restrictions in the metering block.
Re: Holley 6193 idle help needed [Re: 62maxwgn] #2637882
03/27/19 09:22 PM
03/27/19 09:22 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
d
