Page 3 of 8 1 2 3 4 5 6 7 8
Re: Does the Gen III hemi impress you? [Re: WO23Coronet] #2637442
03/26/19 05:53 PM
03/26/19 05:53 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If I was young and tune with modern tech I'd be all over the Gen-3. I've got enough 400 blocks to build what I need for the future. I like the old stuff and I'll stick with it.
Re: Does the Gen III hemi impress you? [Re: hudsonhornet7x] #2637448
03/26/19 06:15 PM
03/26/19 06:15 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Originally Posted by hudsonhornet7x
I have always been into big blocks, strokers and such. Strong small blocks are awesome, always wanted a Gen II hemi, and have been diving into the Gen III world. I bet most of you guys feel the same about the older mopar engines.
My question is what do you guys ( racers, street/strip guys, etc) think of the Gen III engine? Most of the swaps I see are for relatively stock engines, but what about the highly modified engines? Are you impressed with the capabilities that they have shown in an older Mopar, or do you think it is wrong? The gen III is our LS, just want an opinion on what the rest of Moparts thinks.
"First Stocker In The Sevens" is impressive no matter how you handicap or rationalize it.
A Look At Geoff Turk’s Seven-Second Stock Eliminator Engine Effort
'71 Duster
'17 Ram 1500
Re: Does the Gen III hemi impress you? [Re: RMCHRGR] #2637468
03/26/19 07:35 PM
03/26/19 07:35 PM
gregsdart Offline
gregsdart  Offline
If disaster ever strikes my current bigblock drag motor, it would be out of budget to replace it. An alternative i have thought of would be a 6.4 stroked to 426, and my current alky mechanical fuel injection system made to work with a variable runner length stock intake locked in hi rpm position, with the injection nozzles run in the old Injecter bungs using some sort of adapter. A toilet type throttle body could be adapted to the stock intake.
So the cost would be headers, injecter adapters, an adapter ( home made) and toilet tb, stroker kit, machine work, motor plates and ignjtion controller, plus cam ,springs, lifters, head work ought to do it. Off the cuff guess is i could be at 700 plus hp for $6500 or less and i would be within .2 to .3 ET of my $20,000 ++ big block.
Re: Does the Gen III hemi impress you? [Re: hudsonhornet7x] #2637511
03/26/19 09:27 PM
03/26/19 09:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
When I was at the Indy show a few weeks ago, I saw very little in the way of Gen3 stuff there. Or did I miss it. There was some, but I would hazard a guess that Gen3 stuff made up, maybe, 10 to 15% of the floor space. That in itself is an issue.
Master, again and still
Re: Does the Gen III hemi impress you? [Re: gregsdart] #2637513
03/26/19 09:33 PM
03/26/19 09:33 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Stop kicking other mopars. The old hemi does produce a ton of HP in Super Stock and other classes. One problem with the older iron Hemi stuff is it is worn out being pounded for 40+ years. I you want to talk turkey my friends NA World Aluminum Block and FHO Stage V heads at 572 CI on the Dyno made 1365 HP. It is all what you want to build and how long you want to race it before you rebuild it or have to rebuild it. I remember FHO blown 500 CI Hemi with a 14 71 on it. It made a ton of HP near 3000 about 25 year ago in his street car. There all good just run what you like and can afford to replace or repair. I just wish Chrysler had looked a little farther in the future when it came to the new Challenger. The Mustang was out and they were light in weight and Chrysler did not compete with the weight factor comparing the Challenger to the Mustang or even the Camaro. They tried to even the score with a Helper but that is only a bolt on for GM and Ford. I like old motors in old cars and new stuff in new cars. Yes the new tech works wonders so use it on an old motor and put it in an old car. The learning curve is not that tough, all you have to do is ask any kid that runs an SRT4 at the track to explain what to do and what to buy. My son is one of these people and always bugging me to toss the carbs and run fuel management.
1971 HEMI E BODY REGISTRY
Re: Does the Gen III hemi impress you? [Re: WO23Coronet] #2637523
03/26/19 10:23 PM
03/26/19 10:23 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted by WO23Coronet
I think TTI makes a big tube Gen III A body header
That they do. Mine are 2” primary with a 3.5” collector.
Re: Does the Gen III hemi impress you? [Re: gregsdart] #2637545
03/27/19 12:05 AM
03/27/19 12:05 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
very good points Greg. if I was at the point if Id have to buy a aftermarket block......... That's when I'd make the jump. Barring a new iron b block being cast at a descent price point.
Re: Does the Gen III hemi impress you? [Re: moparlulu] #2637565
03/27/19 04:48 AM
03/27/19 04:48 AM
gregsdart Offline
gregsdart  Offline
Another thought,,,,,,,,, add up the cost of prepping a stock block, then subtract that from the cost of a new aluminum block, and how much would it then cost to upgrade? Two other reasons to consider the AL block- Superstockers are now allowed to run the A L block, shed maybe 100 lbs? BUT MAKE another 50 to 60 hp! That is based on results from Dragpack chalengers i know that have switched. Impressive!
Re: Does the Gen III hemi impress you? [Re: pittsburghracer] #2637569
03/27/19 05:16 AM
03/27/19 05:16 AM
jersey
Spaceman Spiff Offline
jersey
Originally Posted by pittsburghracer
Originally Posted by RTSE4ME
Yeah that's the thing with newer builds, lots of 1000 hp dyno queens. Take a look at the more serious HC/Demon guys and you'll see legit et's matching hp claims.
The ingredients are there for a high HP NA build but no ones done it yet
Thats because most change over to turbos.. its easier
wave
and a high HP NA G3 build would probably be the most expensive compared to all other Mopar engine platforms.
Ohhhh ya and the old stuff keeps getting cheaper for me to buy. The Gen3’s are almost as fun beating at the track as the LS Chevy junk.
Real easy to do, when you have a race car, vs a car that drove to the track.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Does the Gen III hemi impress you? [Re: Spaceman Spiff] #2637572
03/27/19 06:40 AM
03/27/19 06:40 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
How could you not be impressed by something like Ray Meyers Car(Sixpackgut). 9.7, 9.8s, pump gas, 3200-3300lbs, stock rocker arms, stock heads ported by him. He took first place in his class on drag week 2016 and didn't turn a wrench on it all week. That wouldn't be easy to do on a small or big block mopar(The ET is easy, the low service and reliability is not)
68 Barracuda Formula S 340
Re: Does the Gen III hemi impress you? [Re: moparlulu] #2637679
03/27/19 11:40 AM
03/27/19 11:40 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I dont see how the gen 3 hemi is considered cheap by any means, junkyard motors are $1500-3000 around here where an LS is like $450...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Does the Gen III hemi impress you? [Re: Bad340fish] #2637691
03/27/19 12:27 PM
03/27/19 12:27 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Been 8.60s at 160s with one in a heavy ass streetcar. stock junkyard block, good internals, stock junkyard heads, stock truck manifolds, a blow through carb, at 3600lbs. And it’s going to go faster with EFI, and some better heads.
Light years ahead of any sb or bb. And way cheaper. You can buy 5.7s for <500 all day.
Re: Does the Gen III hemi impress you? [Re: 1980volare] #2637701
03/27/19 12:50 PM
03/27/19 12:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Like someone said above. Any idiot can go fast with a power adder. Pretty sure this is an NA application post.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Does the Gen III hemi impress you? [Re: pittsburghracer] #2637726
03/27/19 01:47 PM
03/27/19 01:47 PM
cudadoug Offline
cudadoug  Offline
Wow. Any idiot?? Not cool. Pretty sure this was a G3 post, period.
Re: Does the Gen III hemi impress you? [Re: pittsburghracer] #2637728
03/27/19 01:47 PM
03/27/19 01:47 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
ANY IDIOT CAN GO FAST WITH A POWER ADDER....LMFAO ! ! !
WE WILL SEE HOW THAT WORKS OUT FOR YOU I GUESS.....SHM ! LMFAO ! ! ! !
....BAD A$$ STREET CAR.....
Re: Does the Gen III hemi impress you? [Re: n20mstr] #2637729
03/27/19 01:51 PM
03/27/19 01:51 PM
cudadoug Offline
cudadoug  Offline
He must've forgot to take his meds this morning. Again...
Re: Does the Gen III hemi impress you? [Re: astjp2] #2637738
03/27/19 02:10 PM
03/27/19 02:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Used prices are stupid, a brand new (not reman) from dodge is under $1000, a couple eagle heads is a grand. I buy them this way and a couple hundred for a core for the misc pieces and you basically get a brand new motor less than a used engine.
Re: Does the Gen III hemi impress you? [Re: n20mstr] #2637741
03/27/19 02:17 PM
03/27/19 02:17 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
It’s 2019, take your purple cam and 906 heads and bury them in the backyard, take some Metamucil and take a nap.
Re: Does the Gen III hemi impress you? [Re: WO23Coronet] #2637742
03/27/19 02:18 PM
03/27/19 02:18 PM
USA
hudsonhornet7x Offline OP
USA
Although I did not say it, yes this is an N/A post. Everything is fast with forced induction except maybe a corvair monza spyder lol.
I do agree some members here have some quick Gen III engines. I wish we had a block that could make a 500 incher with these good heads.
Re: Does the Gen III hemi impress you? [Re: 1980volare] #2637744
03/27/19 02:24 PM
03/27/19 02:24 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
All the SB and bb guys are mad cause they have $2000+ heads that don’t flow what stock pre eagle heads flow. It’s a lot to take in. Believe I was a SB guy once too.
