Re: 6.4 hemi valves in a magnum eq head
[Re: mgoblue9798]
#2637461
03/26/19 07:14 PM
03/26/19 07:14 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Look at the 5.7 valve also.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2637682
03/27/19 11:52 AM
03/27/19 11:52 AM
RapidRobert
On a side note,if using roller rockers be sure to check wipe pattern & you might need to slightly move the stud hole slightly toward the valley as the roller likely will be way close to the ex side edge of the valve tip. Some have advised against that relocation (not sure of a better option) but when the time comes mockup & go from there. From what I understand there ain't a rocker with short enough fulcrum distances to better this & valve length is certainly gonna play into this. EQ Mag heads are supposed to be a killer.
[Re: RapidRobert]
#2637683
03/27/19 12:04 PM
03/27/19 12:04 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
On a side note,if using roller rockers be sure to check wipe pattern & you might need to slightly move the stud hole slightly toward the valley as the roller likely will be way close to the ex side edge of the valve tip. Some have advised against that relocation (not sure of a better option) but when the time comes mockup & go from there. From what I understand there ain't a rocker with short enough fulcrum distances to better this & valve length is certainly gonna play into this. EQ Mag heads are supposed to be a killer. RR, not sure what you meant by the EQ head being a killer. Is it in regards to valve train geometry? I also have a set of the Indy RHS X magnum style heads that I could use. Thanks for your input.
[Re: astjp2]
#2637684
03/27/19 12:05 PM
03/27/19 12:05 PM
mgoblue9798
Atlanta, GA
Look at the 5.7 valve also. Thank you for the heads up.
[Re: mgoblue9798]
#2637761
03/27/19 03:01 PM
03/27/19 03:01 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I can’t imagine the oe triple keeper groove is going to help with the spring installed height or aftermarket retainer/lock situations.
You can get aftermarket G3 valves that have single bead loc grooves....... but once you’re spending the $$ for aftermarket valves, there are other options as well.
[Re: fast68plymouth]
#2637843
03/27/19 07:22 PM
03/27/19 07:22 PM
Posts: 9,982 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My EQ heads have 8mm LS 2.02 valves in them. The heads needed bronze guides anyway, and the LS valves are + .050 long If i recall correctly. Add a .100 cut to the valve pockets and you have some room for valve lift. I used Olds rocker studs and SBC rockers in 1.6 ratio.
[Re: gregsdart]
#2638088
03/28/19 01:18 PM
03/28/19 01:18 PM
Posts: 3,504 DFW
mr_340
DFW
A friend in Tampa built an R3 engine with the MP aluminum Commando heads (not sure which ones he had). They tried many valves in the heads on a flow bench and the Gen III Hemi intake valve flowed the worst as stock. They machined it and got it to flow the best. They would not share the details with me, but they found a shape and had Manley custom valve for them.
Floyd Lippencott IV
[Re: mgoblue9798]
#2638094
03/28/19 01:33 PM
03/28/19 01:33 PM
RapidRobert
. EQ Mag heads are supposed to be a killer. RR, not sure what you meant by the EQ head being a killer. Thanks for your input. [/quote] A killer as in an excellent head choice. I will choose my words/phrases better.
