Converting a 93 Dakota to Carb Questions #2637422
03/26/19 04:44 PM
03/26/19 04:44 PM
Ohio
DAKOTA93 Offline OP
DAKOTA93  Offline OP
Ohio
I have a 93 Dakota with a 5.2. Plan on dropping in a 5.9 mag with a carb. What would b the easiest way to control the fuel pressure from the stock pump? It has the in tank fuel pump. Would like 2 have a gas gauge. Would just a regulator work? Any suggestions would b greatly appreciated. I would keep the efi but the truck is obd1 so my options are limited not converting it 2 obd2. So just gonna go carb cause the motor will b built a little. Thanks
Re: Converting a 93 Dakota to Carb Questions [Re: DAKOTA93] #2637467
03/26/19 07:35 PM
03/26/19 07:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A fuel regulator with a fuel return will solve the fuel pressure, but I'm not sure the pump will run without the input from the auto shutdown relay, and that relay won't function without the input from the computer that monitors the cam sensor and the throttle position sensor.
Where are you going to get the signal for the dist to function?
Personally, I would just run the 5.9 off the 5.2 OBD1 system and use the 5.9 injectors. May not be optimum, but will run. Unless of course you installing a radical 5.9...Gene
Re: Converting a 93 Dakota to Carb Questions [Re: poorboy] #2637476
03/26/19 07:52 PM
03/26/19 07:52 PM
Ohio
DAKOTA93 Offline OP
DAKOTA93  Offline OP
Ohio
With obd1 your pretty much screwed when it comes 2 cams etc.... I would just run a stock electronic ignition.... wire it up and mostly by pass the computer. The tranny is hydraulic and u can make the lock up and od work with toggle switches. Just need 2 figure a way 2 cut the pressure down
Re: Converting a 93 Dakota to Carb Questions [Re: DAKOTA93] #2637477
03/26/19 07:54 PM
03/26/19 07:54 PM
Ohio
DAKOTA93 Offline OP
DAKOTA93  Offline OP
Ohio
93s have a return line. So it looks like a regulator will work then. Just have read conflicting info on it
Re: Converting a 93 Dakota to Carb Questions [Re: DAKOTA93] #2637495
03/26/19 08:48 PM
03/26/19 08:48 PM
Ohio
DAKOTA93 Offline OP
DAKOTA93  Offline OP
Ohio
My plan was a 5.9 mag with the Hughes Air Gap fi intake a cam and engine quest heads but have been told the Obd1 will not run it right. Looking 2 get 375+ horse with the motor
Re: Converting a 93 Dakota to Carb Questions [Re: DAKOTA93] #2637567
03/27/19 04:53 AM
03/27/19 04:53 AM
Guitar Jones Online laugh2
Converting it to OBD2 isn't that hard. I have a thread on converting my 93 Ram Charger.
OBD2 Conversion
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: Converting a 93 Dakota to Carb Questions [Re: Guitar Jones] #2637927
03/27/19 11:34 PM
03/27/19 11:34 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
what happened to my suggestion?????????
my ladder of success is missing some rungs
