Temp sensor question... #2636924
03/25/19 11:50 AM
03/25/19 11:50 AM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
OK, OK, getting old and the memory ain't what it used to be (and search is no help either). blush
1- Any older Mopars that used a warning light for temperature or did they all have gauges? work
2- If any did, was it simply a ground to illuminate the light? If nothing OE, anything available in the aftermarket?
Reason I ask is to add a warning light to the Charger simply for safety's sake.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Temp sensor question... [Re: I_bleed_MOPAR] #2636946
03/25/19 12:29 PM
03/25/19 12:29 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
on 69 & 70 C bodies, they had a "cold" and "hot" light . . . was a sensor screwed into the water jacket with two wires coming off it (iirc) . . .
Re: Temp sensor question... [Re: I_bleed_MOPAR] #2636948
03/25/19 12:39 PM
03/25/19 12:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My '67 New Yorker had the warning lights; sensor has two terminals, they supply a ground at certain temps. Green light (COLD) on until 140°F then out, red light (HOT) on at 240°F.
Re: Temp sensor question... [Re: John_Kunkel] #2636974
03/25/19 01:50 PM
03/25/19 01:50 PM
Buford, GA
Buford, GA
Thanks. up
Tim
'71 Charger 383/727
Re: Temp sensor question... [Re: I_bleed_MOPAR] #2637324
03/26/19 11:48 AM
03/26/19 11:48 AM
moparx Offline
moparx  Offline
from my old, foggy memory, 66 [or 67] to 70 newyorkers and imperials for sure had that feature, and possibly newports in the 69-70 models.
beer
Re: Temp sensor question... [Re: moparx] #2637377
03/26/19 02:14 PM
03/26/19 02:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 69 70 Imps had it also.They had what was called Signal Sentry.Covered temp oil fuel.Rocky
Chrysler Firepower
