Re: K frame tie downs [Re: n20mstr] #2637272
03/26/19 10:03 AM
03/26/19 10:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted by n20mstr
THESE TIE DOWNS LOOK HEAVY....
Jenny Craig says for the heads up guys to use titanium................. whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: K frame tie downs [Re: hemi-itis] #2637286
03/26/19 10:25 AM
03/26/19 10:25 AM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
In 30 years of towing everything from race cars to 4x4 mud trucks I have never had anything move sideways. All my towing is with a open trailer or ramp truck. Maybe a enclosed trailer makes a difference.
Re: K frame tie downs [Re: n20mstr] #2637292
03/26/19 10:40 AM
03/26/19 10:40 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
2 lbs. total. I weighed mine. I'm a bracket racer, so I'll sacrifice 2 lbs. for a secure car in the trailer.
69 GTX 68 Road Runner
Re: K frame tie downs [Re: JERICOGTX] #2637307
03/26/19 11:14 AM
03/26/19 11:14 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I JUST SPENT A FEW NIGHTS CUTTING OFF
'HITCHIKERS" THOSE ARE THREADS STICKING PAST THE NUT....SO FAR IM UP TO 13OZ....ALMOST A FULL POUND !!!
I DONT CARE WHAT YOU RACE, DIDNT MONTE TEACH YOU ? IF ITS NOT DOING ANYTHING...CUT IT OFF... KEEP TRIMMING, CUTTING ETC....LOL
( VERY NICE BUILD THOUGH ! ! !)
....BAD A$$ STREET CAR.....
Re: K frame tie downs [Re: 1DGEMAN] #2638306
03/29/19 12:01 AM
03/29/19 12:01 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Originally Posted by 1DGEMAN
Originally Posted by AndyF
I designed up some simple little plates that can be welded into the end of the K frame to use as tie down points. I added a pair to my Duster and they seem to work just fine so I'll put these up on the website if anyone else wants them. They do need to be welded into the K frame which can be a dirty nasty job. I had my K frame out of the car and clean when I did the weld so it was easier.
From that location can you criss cross the tie downs without them rubbing? Tie downs should always be crossed to prevent side to side movement.
I have towed thousands of miles, 1200 miles at a time with straight tie downs both front and rear and never had the car move or a strap loosen up. I have seen cars coming into the track pits sideways from a loose cross strap though.
Re: K frame tie downs [Re: rowin4] #2638311
03/29/19 12:25 AM
03/29/19 12:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had my P-body come loose in the enclosed trailer.. a slick went
flat.. the fronts were crossed and the rears were straight... the
right slick went down and the strap went loose and the strap
bounded off.. car bounded to the right and that strap bounced
off.. at least it didnt go forward being it was in park.. I had to redo
both sides of the car.. now I just put a bungy between the 2 rear
straps.. that was the only issue I have had
wave
Re: K frame tie downs [Re: JERICOGTX] #2638642
03/29/19 10:29 PM
03/29/19 10:29 PM
hemi-itis Offline
hemi-itis  Offline
Is that each or all 4? scope
