Weight Distribution Bias??
#2636599
03/24/19 07:32 PM
03/24/19 07:32 PM
Posts: 2,533 Alexandria, LA
Blucuda413
Alexandria, LA
Over the last 3 yrs I have changed my car considerably. It was a 68 Notchback, backhalved, PG, 8 3/4, 413ci smallblock, W2 heads, 950 Holley, roller cam, JE pistons with 6.4 rods, weight 2940. The cars best in that configuration was a 6.32 1/8mi. Things I have done include an aftermarket 9", alum driveshaft, built a 413ci blower motor, and replaced stock front suspension with my design K member, Lamb struts and R&P steering. I was concerned about increase in weight primarily because of that heavy blower however after I scaled it I was surprised that I lost 40lbs on the front. The car now weighs 2900 with 50.03% on the rear. I would have had more on the rear but I moved the engine forward 2 inches and raised it 2 inches off the stock frame rails instead of cutting and reworking the trans cross member. I have not dynoed it and I haven't had it on the track because I'm still playing with the Holley bugcatcher injection so I don't have any idea how it will perform. I guess my question is typically where in the performance spectrum is it usually required for the weight bias to move to the front rather than the rear?
Re: Weight Distribution Bias??
[Re: Blucuda413]
#2636656
03/24/19 09:32 PM
03/24/19 09:32 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
When it wheelstands higher and/or harder than you want it to. Moving the engine out and up 2" is a big move. You may wish you had lowered it. 50% is nice though. Ladder bar or 4 link?
[Re: RustyM]
#2637021
03/25/19 04:07 PM
03/25/19 04:07 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
On one extreme, you have a car that wants to climb the ring gear, hit the bars hard and unload the rear tires. On the other, it has no pitch rotation or weight transfer and spins the tires. Balance is just part of the equation. A hundred other things are part of it as well. And there are things one can do to compensate or adjust for less than optimum bias. Some cars are not that sensitive. Others - big power, small radial tire - can go from dragging the bumper to blowing the tires off just by moving 10 or 15# around in the car
[Re: RustyM]
#2637101
03/25/19 07:36 PM
03/25/19 07:36 PM
Posts: 9,824 MI, usa
dvw
MI, usa
900 HP- SHEESH!! IF Your ever going to be in East or Central Texas, i would like us to get together and buy your lunch/pick your brain.
At 700 hp, 3400 lbs- what would you like to see on weight bias ( 65 b body)?
At 650 hp, 2850 lbs - what weight bias do you like to see ( 72 duster) ? What SLR? Tire size and type, Suspension type? All make a difference. We are trying to attempt to get the car to make nearly a complete revolution of the tire before the front tire comes off the ground. Haven't accomplished that yet but getting close. The 60 ft still dropping and consistency getting better. My bet is the B body at that weight and power won't be to picky, but the A body??? You can try 50/50 but I'd have the front travel tied up and a pair of wheelie bars. Doug
