Which tank/pump, harness/computer for '14 5.7 in 70 chally? #2627988
03/02/19 05:52 PM
03/02/19 05:52 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
What is the best option for fuel system in a 70 challenger getting a stock(and staying stock) 2014 395hp truck 5.7 hemi?Will also need to buy wiring harness and computer as well.Looking for best value and simplicity,newbie to this.....
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2628144
03/03/19 01:35 AM
03/03/19 01:35 AM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
Budget?
I recommend Tanks inc. I got a new tank, and pump. And the line kit with the corvette filter. Get the relay kit as well. All worth the money.
Wiring, you will,get tons of opinions. I did the Holley HP kit. Still putting it all together.
Good luck.
Nothing is super cheap about this swap.
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2628799
03/04/19 06:19 PM
03/04/19 06:19 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Easiest option is maybe fit a car intake and accesories and use the Mopar Performance crate kit. If you want to keep the truck stuff you can always mod and tune the MP crate kit to fit.
If you had the pcm and harness that came with that engine you could have modded them to fit
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2628832
03/04/19 07:44 PM
03/04/19 07:44 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
EFI source Gold Box and a Tanks Inc drop in tank.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2628836
03/04/19 08:06 PM
03/04/19 08:06 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Agree with the efi source gold box with harness, runs about 1300 for that. I went with the spectra efi tank for my cuda, got lucky and only paid 110 shipped from amazon for it. They have a walbro 255 pump in them.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: Silver70] #2629122
03/05/19 01:26 PM
03/05/19 01:26 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
we will likely go with the spectra tank ,its a cpl hundred bucks cheaper unless there is a good reason not to.The efisource gold box and harness are reliable and user friendly?
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2629382
03/05/19 09:33 PM
03/05/19 09:33 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
While I have no qualms with the Gold Box reliability, I do try to ensure people know what they'e getting into.
I'd consider the Gold Box to be playing the game on "expert mode", you put all the inputs in and make it run well, or make it run terribly. I'd say the Mopar kit is likely the "beginner" mode, you get the turn-key new car like engine, but there are some capacity constraints if you try to step it up from there.
That said, I have 5,000+ miles on my Gold Box along with a Tanks tank and a JakeFab puck/Aeromotive pump.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 Subaru WRX - E30 Tune ~320whp
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2635136
03/21/19 10:43 AM
03/21/19 10:43 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
Spectra tanks are sold by Rockauto.com. Look for a discount code as well...
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: dickdale] #2635421
03/22/19 01:49 AM
03/22/19 01:49 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Another very low cost option if you hunt around is get a factory harness and pcm and spend a little time to modify it and reflash the factory pcm to run stand alone and you can have a kit as good as the MP standalone kit for 25% of the price of the MP kit or Gold box
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: L4staero] #2635894
03/23/19 11:45 AM
03/23/19 11:45 AM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
thanks for all the info and replies guys,the mp kit does seem quick and easy,any drawbacks ? we are not going to mod the engine so thats no concern.And is there a reason the mp kit does not work with a truck engine?
I do need to start getting all the hard parts gathered up as well,motor mounts,exhaust manifolds,intake manifold(will any car 5.7 manifold work? ) ,front accessory drives etc.........looking for advice in that regard as well..!!
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2636506
03/24/19 04:12 PM
03/24/19 04:12 PM
Australia
L4staero Offline
L4staero  Offline
Australia
MP says the kit doesnt work with truck engines for 2 main reasons. 1 is alot of the connectors will be in the wrong place due to the location of different accesories etc and 2 from memory the truck 5.7 has a slightly different cam and a dual length itake manifold so the tune will be off a little
Re: Which tank/pump, harness/computer for '14 5.7 in 70 chally? [Re: ogopogo] #2713509
11/06/19 09:00 PM
11/06/19 09:00 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
what year car intake manifolds will fit or work on this truck motor? lots of used ones out there.Gonna start ordering parts for this thing asap,any advice appreciated!
How to adjust transmission/throttl
e linkage?
by 67SATisfaction. 06/04/20 11:44 PM
Deformed '70 'Cuda Tail Light Bezels
by Grizzly. 06/04/20 11:20 PM
Moparts Recent Posts
Chevelle board? A question on the 396/402
by Diego (not Ted). 06/05/20 01:46 AM
new SFT for the 511
by Cab_Burge. 06/05/20 01:31 AM
