2006 dakota trans issue ? #2636200
03/23/19 10:53 PM
03/23/19 10:53 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
found one on line with newer transmission but was informed it wasnt shifting any idea on the issue
Re: 2006 dakota trans issue ? [Re: theraif] #2636222
03/23/19 11:39 PM
03/23/19 11:39 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
3.7 or 4.7 ???
Re: 2006 dakota trans issue ? [Re: 135sohc] #2636235
03/24/19 12:51 AM
03/24/19 12:51 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
3.7
Re: 2006 dakota trans issue ? [Re: theraif] #2637404
03/26/19 03:35 PM
03/26/19 03:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the filter in the pan splits at the seams, I always start there and it cures most issues I have seen with the 45rfe trans
Re: 2006 dakota trans issue ? [Re: HotRodDave] #2639405
03/31/19 10:46 PM
03/31/19 10:46 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Didn't think a 3.7 would have a 45rfe. But your right on the filter issues seen alot of replacements and overhauls for a bad filter to pump seal.
Re: 2006 dakota trans issue ? [Re: theraif] #2639626
04/01/19 12:24 PM
04/01/19 12:24 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
It should have the light duty 42RLE. Basically a FWD transmission adapted from the 42LE to make the power flow go out the back.
Solenoid pack, Low & reverse switch valve ect... Without a diag and pulling codes it is a total shot in the dark as to what could have failed.
