Re: Carter P4070 Electric Fuel pump shuts off?
[Re: mopars4ever]
#2636058
03/23/19 06:14 PM
03/23/19 06:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
might be overheating the pump and tripping a thermal cutout. You really need to get in there with a meter when it's happening and see what's missing.
[Re: 6T9RR]
#2636067
03/23/19 06:37 PM
03/23/19 06:37 PM
Posts: 15,197 Omaha Ne
TJP
Omaha Ne
The oil pressure switch shouldn't be carrying the electrical load because I have the pump wired through a relay. At least that is what I thought the relay is for, to carry the load once it is switch on, the oil pressure switch will turn the relay off if oil pressure is dropped off below 5 - 3 psi. I do appreciate the input thought. Providing the relay is wired properly, the connections are all good,The relay and wiring are sized properly about the only thing left is a flaky ground. Doubtful you would get two bad pumps in a row but possible. ' A schematic would help Have you tried a failed pump off the car??? Maybe check the resistance across the terminals?? Next stop might be to call their tech support.
[Re: TJP]
#2636092
03/23/19 07:27 PM
03/23/19 07:27 PM
Posts: 88 Oregon
6T9RR
I've double checked the wiring itself, all things look good, gauge, connections, grounds, as for the oil safety switch, I'll have to look into checking to see if it is operating correctly. I have read about thermal shut downs on these pumps happening, I'll have to work on wiring up a multi-meter to see if I can detect when it is shutting down, then checking the pump to see if it is hot. Again, I do appreciate all inputs, this has been an issue since I put the first P4070 in last September.
[Re: calrobb2000]
#2636265
03/24/19 08:27 AM
03/24/19 08:27 AM
Supercuda
About to go away
About to go away
up yours
hi hi you must have the right psi switch , it will need to be a n o switch . < normaly open > psi will close the contacts to run te pump. It runs for a while then shuts down. The switch isn't magically changing from NO to NC.
[Re: Supercuda]
#2636459
03/24/19 02:23 PM
03/24/19 02:23 PM
TJP
Omaha Ne
hi hi you must have the right psi switch , it will need to be a n o switch . < normaly open > psi will close the contacts to run te pump. It runs for a while then shuts down.The switch isn't magically changing from NO to NC. However, if the Oil pressure switch is not and on / off type switch, but rather one that varies the resistance to ground via the oil pressure being being produced ( think gauge sending unit), it could cause some issues activating the relay coil keeping in mind the resistance changes as the engine warms up and the pressure drops. Roberts idea is also not a bad one as it would identify the circuitry or the pump as the culprit keep us posted
[Re: TJP]
#2636540
03/24/19 05:09 PM
03/24/19 05:09 PM
Supercuda
About to go away
About to go away
up yours
Well switch does imply on/off and sender implies variable resistance. So assuming he does have a switch like he stated then that should not be it. But if he had a sending unit instead then yeah that might be an issue but he'd have to have something like a temperature sender that changes as it gets hot. Oil pressure sender would pretty much change immediately once the engine is running.
[Re: 6T9RR]
#2636953
03/25/19 01:02 PM
03/25/19 01:02 PM
Posts: 855 ontario canada kingston
aspenrt360
Nice, keep us informed please.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: stumpy]
#2643431
04/09/19 09:21 PM
04/09/19 09:21 PM
Supercuda
About to go away
About to go away
up yours
Diplomats used a similar switch to power the choke only when the engine was running. Since his FP is on a relay that switch would also work fine for his setup.
