Re: Starting to work on the Duster
[Re: Airwoofer]
#2665687
06/14/19 12:04 AM
06/14/19 12:04 AM
Posts: 31,050 Oregon
AndyF
[Re: AndyF]
#2665753
06/14/19 09:39 AM
06/14/19 09:39 AM
Posts: 10,037 MN
JERICOGTX
MN
Coming along nicely Andy.
69 GTX
68 Road Runner
[Re: AndyF]
#2665949
06/14/19 07:05 PM
06/14/19 07:05 PM
AndyF
Once the engine is hoisted into place the suspension assembly (K frame, lower control arms, steering box, steering linkage, knuckles, hubs, caliper brackets, anti-sway bar, etc.) is lifted into place using a fixture on my transmission jack. Screw home the four big bolts and then start attaching stuff.
[Re: AndyF]
#2666080
06/15/19 03:58 AM
06/15/19 03:58 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Looks great Andy, can't wait to see it out.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: AndyF]
#2666163
06/15/19 11:04 AM
06/15/19 11:04 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Looks amazing Andy! I see you installed a distribution block with the 4 wheel disc brakes. My 4 wheel Wilwoods kinda suck, the front brakes are too small, and I think I need the smaller bore master cylinder but I've also had people tell me the distribution block can be removed with 4 wheel disc. I hate to remove it though because all the lines are nicely bent to it.
[Re: ProSport]
#2666177
06/15/19 12:18 PM
06/15/19 12:18 PM
AndyF
Looks amazing Andy! I see you installed a distribution block with the 4 wheel disc brakes. My 4 wheel Wilwoods kinda suck, the front brakes are too small, and I think I need the smaller bore master cylinder but I've also had people tell me the distribution block can be removed with 4 wheel disc. I hate to remove it though because all the lines are nicely bent to it. Whoever told you that probably didn't know the difference between a distribution block and a proportioning valve. A distribution block is just a block of brass with holes drilled in it. It doesn't do anything to brake pressure. It is just a couple of T fittings that are joined together so there is no reason to remove it or not use it. The question about using a prop valve with 4 wheel disc brakes is more complicated. In theory you don't need one but for home built brake systems it is probably a good idea to install one. Most people don't know how to design a brake system so having some adjustment built in is probably a good idea.
[Re: AndyF]
#2666419
06/16/19 09:37 AM
06/16/19 09:37 AM
ProSport
Akron, Ohio
Ok thanks Andy. I really like your Baer master Cylinder setup.
[Re: AndyF]
#2667176
06/18/19 12:29 PM
06/18/19 12:29 PM
Posts: 625 Indianapolis In. usa
Quickrunner
I like it! Ran one on my roadrunner with a K&N element for few seasons before switching to dominator carb.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: AndyF]
#2667180
06/18/19 12:47 PM
06/18/19 12:47 PM
Posts: 17,875 S.E. Michigan
ZIPPY
S.E. Michigan
That's coming along amazingly well. The paint job makes it hard to recognize as the same car.
It seems to have a good blend of Vintage Mopar content with updates/electronica to appeal to a wide audience.
Rich H.
Esse Quam Videri
[Re: AndyF]
#2671779
06/30/19 12:34 AM
06/30/19 12:34 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Very, very nice chrastmanship as usual!! I know that those Braille batteries are very good, but do they hold a charge for cars that sit for a couple of weeks at a time with no maintainance charge hooked up?
