'69 RR - what are these bolts for ?? #2635320
03/21/19 07:28 PM
03/21/19 07:28 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The circled bolts. One on each side. These are NOT seat belts or exhaust hangers. It would appear that they bolt the rear floor section to the frame rails for assembly at the factory!!
Re: '69 RR - what are these bolts for ?? [Re: Stanton] #2635331
03/21/19 07:59 PM
03/21/19 07:59 PM
Originally Posted by Stanton
The circled bolts. One on each side. These are NOT seat belts or exhaust hangers.n to the frame rails for assembly at the factory!!
Probably NOT tsk All the main body parts for the rear half of unibody cars are welded on, not bolted shruggy
If they bolted them together before welding it would take a lot more than two bolts, correct? work shruggy
The exhaust hanger brackets should be welded onto the bottom of the floor near where your bolts are confused
I wish I had the correct answer for you but I don't whiney
Re: '69 RR - what are these bolts for ?? [Re: Cab_Burge] #2635335
03/21/19 08:09 PM
03/21/19 08:09 PM
Ohio
lockjaw-express Offline
Ohio
My 1969 GTX does not have them...is that an AMD mod?
That is if you bought their floor pans.
Mark
Re: '69 RR - what are these bolts for ?? [Re: Stanton] #2635342
03/21/19 08:28 PM
03/21/19 08:28 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I believe you are correct. The rear frame rails were set in a jig with the floor pan. I think that these two bolts tied everything together before being welded together. Both my 68 and 69 road runners have them. And a 69 coronet I recently parted had them too.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: '69 RR - what are these bolts for ?? [Re: RoadRunner] #2635353
03/21/19 08:48 PM
03/21/19 08:48 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
According to the Dave wise book they are for floor alignment
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: '69 RR - what are these bolts for ?? [Re: 1969gtx] #2635380
03/21/19 09:27 PM
03/21/19 09:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've always thought that as well. Kind of stacked washers under there too to temporarily hold some things together until final fitment..
Re: '69 RR - what are these bolts for ?? [Re: buildanother] #2636421
03/24/19 01:13 PM
03/24/19 01:13 PM
THUNDER BAY
Doctordodge Offline
Doctordodge  Offline
THUNDER BAY
Are they not to hold down the rear seat back cushion? Some cars used metal tabs folded over and others had bolts I believe.
Re: '69 RR - what are these bolts for ?? [Re: Doctordodge] #2636518
03/24/19 04:32 PM
03/24/19 04:32 PM
chicagoland,usa
chicagoland,usa
No, they're different and mine were fogged the same color as floor. They bolt right into subframe IIRC.
Re: '69 RR - what are these bolts for ?? [Re: buildanother] #2636525
03/24/19 04:41 PM
03/24/19 04:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My 68 Charger have the same,
