Re: DOT or NOT? [Re: ZIPPY] #2635418
03/22/19 01:30 AM
03/22/19 01:30 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
My Hoosier QTP Dot I just got a few months ago has "For Competition Use Only " on it. Even though it has the DOT on it also.
Re: DOT or NOT? [Re: 62SAVOY] #2635519
03/22/19 10:51 AM
03/22/19 10:51 AM
moparx Offline
moparx  Offline
and the new demon comes with four DOT "???" tires [i forgot] from the factory ? as such, those will get driven on the street [some] correct ?
beer
Re: DOT or NOT? [Re: moparx] #2635684
03/22/19 07:49 PM
03/22/19 07:49 PM
fullmetaljacket Offline OP
IIRC, Demons are possessed by ?? rating Nitto's on all four corners. Wonder how Mother Mope got those pass the highway patrol.
With this scenario, I'm taking second looks first time.
Re: DOT or NOT? [Re: fullmetaljacket] #2635785
03/23/19 07:23 AM
03/23/19 07:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Demon tire and all Nitto drag radials seem to have sufficient tread to not kill you in a rainstorm if the tires are fresh.
68 Barracuda Formula S 340
Re: DOT or NOT? [Re: Bad340fish] #2635832
03/23/19 09:38 AM
03/23/19 09:38 AM
moparx Offline
moparx  Offline
i just thought of something. those nittos have a demon emblem in the side wall, correct ? if so, i wonder if those tires have some extra "tread" molded in as well to get it "highway approved" [sorta] ?
beer
Re: DOT or NOT? [Re: moparx] #2635890
03/23/19 11:36 AM
03/23/19 11:36 AM
I would suspect is the deepness of the threads, how far apart are they from each other and the sidewall construction as far as number of ply's. Side loads in an emergency as in swerving hard could compromise the sidewalls or the ability for the tire to stay seated on the rim bead.
Re: DOT or NOT? [Re: fullmetaljacket] #2635899
03/23/19 11:49 AM
03/23/19 11:49 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Most of you are dealing with fair weather toys,so we want to achieve max traction when we stomp it!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: DOT or NOT? [Re: hemi-itis] #2635900
03/23/19 11:57 AM
03/23/19 11:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
DOT either approves or rejects ALL tires.. they have a series of tests
that the tire MUST meet to be approved FOR THE DESIGNED
PURPOSE .. they do fail tires that are unsafe
wave
