caltrac no prep #2634955
03/20/19 08:20 PM
03/20/19 08:20 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
just put caltracs on my car with split monoleaf had stock leaf springs clamped with sliders and it hooked pretty good. they have a place here that they run on the straight away of a road race track. so there's no prep at all. with the stock spings I could just jump it out and flat foot it and it would go. it would do that anywhere . I took the car out last night and road around and got on it a couple times and it was just blowing the tire's I.have the caltracs set just touching no preload. shocks set the same as before pretty much 9 clicks out of 18. 69 satelite 472 13X31 quick time pros. I'm going to call calvert tomorrow. what would you set the caltracs loose or preload
Re: caltrac no prep [Re: plycuda] #2634964
03/20/19 08:31 PM
03/20/19 08:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used to adjust mine to touch and one turn of pre-load but that was a stick car with drag slicks shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: caltrac no prep [Re: fourgearsavoy] #2635004
03/20/19 10:40 PM
03/20/19 10:40 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Use what you have as a baseline and test from there.How much front end travel do you have,they would like 5 to 6 inches.Are you bias or radial??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: caltrac no prep [Re: hemi-itis] #2635306
03/21/19 06:09 PM
03/21/19 06:09 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
it has easy 5 plus travel and bias tires. calvert told me try 1/4 turn preload both sides and tighten the shocks. I guess I will see
Re: caltrac no prep [Re: plycuda] #2635309
03/21/19 06:25 PM
03/21/19 06:25 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
That helped a ton on my Roadrunner.
One flat of pre-load and my shocks are on 8 of 9 toward stiff.
5 Speed, 469, 29x12 Goodyear, leaving at 6000
Re: caltrac no prep [Re: Biginchmopar] #2635402
03/21/19 10:55 PM
03/21/19 10:55 PM
hemi-itis Offline
hemi-itis  Offline
Like button! beer
