Victor or Trickflow intake
#2634940
03/20/19 07:06 PM
03/20/19 07:06 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm going to a single plane intake this year and I wonder if there is a big difference in either manifold. I have an Edelbrock Performer RPM on the engine now but I am looking down the road at EFI and that doesn't really work well with a dual plane intake. There is also Speedmaster intake that looks a lot like the Victor but has EFI bungs installed but they are out of stock right now. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Victor or Trickflow intake
[Re: fourgearsavoy]
#2635088
03/21/19 08:19 AM
03/21/19 08:19 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I have only ran the Victor personally but I can tell you the trick flow is cast alot cleaner in The plenum area. If the trick flow was available and affordable at the time I probably would have got it instead.
The victor is nice but has 4 restrictive "wings" cast into the corners at the carb pad. While it's not a whole lot of work to get rid of them and blend a little while you're in there (Highly recommended), it's time spent. Nothing wrong with it once it's Prepared.... but it really shouldn't be cast that way.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2635110
03/21/19 09:22 AM
03/21/19 09:22 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
The victor is nice but has 4 restrictive "wings" cast into the corners at the carb pad. While it's not a whole lot of work to get rid of them and blend a little while you're in there (Highly recommended), it's time spent. Nothing wrong with it once it's Prepared.... but it really shouldn't be cast that way. Have you ever dyno tested with and without the "wings" you recommend removing? I have.
[Re: LaRoy Engines]
#2635322
03/21/19 07:30 PM
03/21/19 07:30 PM
BradH
The victor is nice but has 4 restrictive "wings" cast into the corners at the carb pad. While it's not a whole lot of work to get rid of them and blend a little while you're in there (Highly recommended), it's time spent. Nothing wrong with it once it's Prepared.... but it really shouldn't be cast that way. Have you ever dyno tested with and without the "wings" you recommend removing? I have. So have I, and we've both posted our results on an older thread. When I did it, I picked up about 10 HP on a 600 HP 440. As I recall, your test on a different build showed a loss.
[Re: 451Mopar]
#2635350
03/21/19 08:39 PM
03/21/19 08:39 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Didn't get mine from Summit but had no problem getting one. Ordered it 2 weeks ago and had it 2 days later.
Ok
[Re: cudatom]
#2635390
03/21/19 09:53 PM
03/21/19 09:53 PM
fourgearsavoy
Rittman Ohio
Well it looks like the Trick Flow intake is the one for me. I will be replacing my Solid Indy valley plate with a 2 piece unit like I should have done when I built this engine. The billet Trick Flow part looks like it should fit with Indy heads,they offer two styles looks like one for the 240 and one for the 270. I will take my Indy plate to Summit and compare it and see if it will work. I'm not looking for huge gains over the Performer RPM just something different to go with the new cam. Thanks for the replies. Gus
[Re: BradH]
#2635468
03/22/19 08:52 AM
03/22/19 08:52 AM
ZIPPY
S.E. Michigan
I don't know why he would care, but in an attempt to be human and friendly about it I've sent LaRoy some background. If anyone wants to send me another Victor 383 manifold that hasn't had this work done, I'll test it right away
Rich H.
Esse Quam Videri
[Re: RalleyA12]
#2635898
03/23/19 11:49 AM
03/23/19 11:49 AM
BradH
Not to " muddy the waters" or steal this post, but how would the Mopar 337 manifold compare if thrown into the mix ? Not exactly an apples-to-apples comparison, since the 337 is a MW intake and the others mentioned are standard port models.
[Re: Dunnuck Racing]
#2635902
03/23/19 11:59 AM
03/23/19 11:59 AM
BradH
As cast, there is a big difference on the flow bench Have not compared them on the dyno as of yet. But there is a clear advantage to the Trick flow as some of the work needed to make the Edelbrock work better is already done I had intended to include a comparison of the Trick Flow RB intake against a Victor in my last dyno session. However, the port alignment was a good bit off between the two intakes and I didn't have the time (nor want to spend the $) to get them milled to equalize the differences. FWIW, I also believe there are some things about the as-cast Trick Flow that give it an advantage over an unmodified Victor. EDIT: Based on the pics of the Speedmaster intake I've seen, I suspect that one of those would require a good amount of work to even be the equivalent of an unmodified Victor.
[Re: AndyF]
#2636000
03/23/19 04:40 PM
03/23/19 04:40 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I just pulled this engine off the dyno. 610 hp and 630 ft-lbs of torque with the Trick Flow intake and Trick Flow heads. This is a pump gas engine with 239/245 hyd roller cam. Might be one of the best street engines I've ever run on the dyno. What I'm doing these days is ordering the Trick Flow intake from Hughes Engines with their deep port match already done. That way I don't have to mess with it. Hughes has a CNC program on hand as well as the correct fixture so I don't see any reason to eat chips on my bench when they have it figured out. I highly recommend using the Hughes deep port match even if you're planning on doing some plenum work yourself. Might as well get the dirty work done by them and just do the fun stuff yourself. I will be curious to see the reliability of the hyd roller cam. I tried one in the street car (ran 13.3 at 4525 lbs) and I floated the valves. It really wanted to rev well over 6000 and somewhere around 6000 it was floating. I am installing the cam in my spare motor. What RPM are you running?
[Re: ZIPPY]
#2641266
04/04/19 06:26 PM
04/04/19 06:26 PM
fourgearsavoy
Rittman Ohio
The victor is nice but has 4 restrictive "wings" cast into the corners at the carb pad. While it's not a whole lot of work to get rid of them and blend a little while you're in there (Highly recommended), it's time spent. Nothing wrong with it once it's Prepared.... but it really shouldn't be cast that way. So the price on the Victor has dropped to $307 so I'm thinking of going that route and do some work on it. Summit kind of makes me mad because they won't place the order on the Trick Flow until they hit their discount number. I can have the Victor next week but they cant get me a Trick Flow until next month. Gus
[Re: fourgearsavoy]
#2641281
04/04/19 07:16 PM
04/04/19 07:16 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That’s funny.
They have to have so many on order to get their discount from TF.......... which is owned by Summit.
So many on order before they can discount it to themselves.
[Re: BradH]
#2641382
04/04/19 11:25 PM
04/04/19 11:25 PM
Posts: 30,994 Oregon
AndyF
... What I'm doing these days is ordering the Trick Flow intake from Hughes Engines with their deep port match already done. That way I don't have to mess with it. Hughes has a CNC program on hand as well as the correct fixture so I don't see any reason to eat chips on my bench when they have it figured out. I highly recommend using the Hughes deep port match even if you're planning on doing some plenum work yourself. Might as well get the dirty work done by them and just do the fun stuff yourself. I don't see that option on their web site. Dare I ask how much Hughes adds to the cost of a $350 intake for their "deep port match"? You'll have to call and ask. They have a DPM option on some of their intakes but not all. I believe that is just because they haven't updated the website with all of the available options. I called them and asked for a Trick Flow intake with the Deep Port Match and they said no problem, be a couple of weeks. So they can do it but it isn't listed on the website for the TF intake. Here is an example: http://www.hughesengines.com/Index/...e=partnumber&page=2&partid=27651
[Re: markz528]
#2641561
04/05/19 12:43 PM
04/05/19 12:43 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
My 440 source headed 505 has a hydraulic roller about the same size as Andys. Used Isky 8005A valve springs and haven't noticed any valve float up to 6,000 RPM. I have the rev-limiter set at 6,000 so I never ran it past that, but it does rev really fast and easy to 6,000? The Trick flow 240 headed 505 we are building for a friend, has a slightly larger 242 @ 0.050" solid roller, and using the solid roller valve spring / Ti retainer version of the Trick Flow heads. Right now the car that engine is going into has no rev-limiter, so it may "accidently" see over 6,000 RPM?
[Re: BradH]
#2641585
04/05/19 02:09 PM
04/05/19 02:09 PM
fourgearsavoy
Rittman Ohio
... What I'm doing these days is ordering the Trick Flow intake from Hughes Engines with their deep port match already done. That way I don't have to mess with it. Hughes has a CNC program on hand as well as the correct fixture so I don't see any reason to eat chips on my bench when they have it figured out. I highly recommend using the Hughes deep port match even if you're planning on doing some plenum work yourself. Might as well get the dirty work done by them and just do the fun stuff yourself. I don't see that option on their web site. Dare I ask how much Hughes adds to the cost of a $350 intake for their "deep port match"? It looks like it would be over 5 bills for the intake without shipping for the basic deal. I still need pushrods,springs,retainers,gaskets,and misc. There always seems to be a lot of misc. I just don't think I need a $500 intake at this point Gus
[Re: fourgearsavoy]
#2642057
04/06/19 07:45 PM
04/06/19 07:45 PM
fourgearsavoy
Rittman Ohio
Well it turns out Moparts to the rescue again Fran(10SecGTX) was looking for a dual plane intake for his wagon and had a Victor on the GTX so we made a deal Nice when friends come together and everybody gets what they need. Thanks again Fran now lets get that HEMI box in the wagon Gus
[Re: fourgearsavoy]
#2647446
04/21/19 01:25 AM
04/21/19 01:25 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Well it turns out Moparts to the rescue again Fran(10SecGTX) was looking for a dual plane intake for his wagon and had a Victor on the GTX so we made a deal Nice when friends come together and everybody gets what they need. Thanks again Fran now lets get that HEMI box in the wagon Gus Gus will you be running your car with the Victor intake and a carb still on it?? If so I will be interested in the results ? I believe our engines are close in build and I use the Indy dual plane and have been thinking of trying the MP 337 single plane one day as its about the only single plane that will fit under my hood. So I would love to see how the single plane works on your combo ? Ron
[Re: 383man]
#2647575
04/21/19 02:52 PM
04/21/19 02:52 PM
fourgearsavoy
Rittman Ohio
Well it turns out Moparts to the rescue again Fran(10SecGTX) was looking for a dual plane intake for his wagon and had a Victor on the GTX so we made a deal Nice when friends come together and everybody gets what they need. Thanks again Fran now lets get that HEMI box in the wagon Gus Gus will you be running your car with the Victor intake and a carb still on it?? If so I will be interested in the results ? I believe our engines are close in build and I use the Indy dual plane and have been thinking of trying the MP 337 single plane one day as its about the only single plane that will fit under my hood. So I would love to see how the single plane works on your combo ? Ron Ron I hope this deal fits under my hood but maybe it's time to put the MaxWedge scoop on the car. I have one in my parts stash I just need to have it painted and carve a hole in my hood. I'm going with a new cam 616/620 lift 260/264 duration also so it wont be a direct comparison to the dual plane. I'm going to fatten it up a little bit just to be safe. I also jumped from a 3.54 to a 4.10 and that should keep my low end strong. I will still have to order some pushrods because from what I've read about EDM lifters they are slightly taller than the standard flat tappets. The car "should" go quicker and faster but we'll see Gus
[Re: fourgearsavoy]
#2647584
04/21/19 04:13 PM
04/21/19 04:13 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Anyone of experience with a Dominator on a trickflow?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
