Re: Prestige Motorsports 572 Street Hemi
[Re: rickseeman]
#2634844
03/20/19 02:11 PM
03/20/19 02:11 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Never heard of them either........ not that that means anything.
They’re certainly located in an area where there should be plenty of talent.
My question would be....... if they don’t have a block on hand for your build....... where are they going to get one?
[Re: Craig J]
#2634855
03/20/19 02:51 PM
03/20/19 02:51 PM
Posts: 17,837 S.E. Michigan
ZIPPY
S.E. Michigan
No, but here is a bump to the top.
They did come up in research a couple times when I started mine.
If it is the company I am thinking of, they have a really smooth running one on youtube that would probably appeal to those into milder engines.
I think that one had an aluminum block but can't recall...
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2635010
03/20/19 10:59 PM
03/20/19 10:59 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I couldn't buy a crate for any engine without checking everything !! I have heard too many stories........... There are a few engine builders that can be trusted but....................
[Re: Craig J]
#2635152
03/21/19 11:02 AM
03/21/19 11:02 AM
hemi-itis
IMOP your so much better off getting a block when you can find one,even a used block as your a streeter,There are many choices for cylinder heads available as is rocker gear.There is also a large selection of internal parts to choose from that YOU could choose. Do you have a GOOD machine shop near you that is capable of blueprinting your project? I think you could accomplish your desire for less then a Barton crate!
[Re: hemi-itis]
#2635169
03/21/19 11:39 AM
03/21/19 11:39 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hemi - itis, that one one bad engine you have there!
2 kids and a dog
