STOCK 400 (LATE 70'S) QUESTION #2633023
03/15/19 01:25 PM
03/15/19 01:25 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Not taken apart yet, but I'm buying a t. chain and gears for a 400 I've bought to use. Is it a single bolt or 3 bolt style cam gear?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: STOCK 400 (LATE 70'S) QUESTION [Re: Magnumguy] #2633038
03/15/19 02:18 PM
03/15/19 02:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Unless someone swapped it all 400's are single bolt cams
Don't be the exception.
Re: STOCK 400 (LATE 70'S) QUESTION [Re: Magnumguy] #2633110
03/15/19 05:53 PM
03/15/19 05:53 PM
& get a 3 keyway set & adv it
Re: STOCK 400 (LATE 70'S) QUESTION [Re: RapidRobert] #2633118
03/15/19 06:23 PM
03/15/19 06:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as far I know the only 3 bolts camshaft used on BB Mopars was the 6 pack cam, which is the same magnum camshaft with just the 3 bolts setup difference
Re: STOCK 400 (LATE 70'S) QUESTION [Re: NachoRT74] #2633253
03/16/19 10:02 AM
03/16/19 10:02 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
What are you dropping this one into Bill?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: STOCK 400 (LATE 70'S) QUESTION [Re: DynoDave] #2634738
03/20/19 10:24 AM
03/20/19 10:24 AM
S.E.Ohio
S.E.Ohio
Long story Dyno. I'll fill you in sometime. We need to chat at some point.
Re: STOCK 400 (LATE 70'S) QUESTION [Re: Magnumguy] #2635174
03/21/19 11:48 AM
03/21/19 11:48 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I know. We keep missing each other by phone / text.
DynoDave
Member # 12304
