adding PCV #2634593
03/19/19 09:11 PM
03/19/19 09:11 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i want to add a PVC to these valve covers, what would be my best course of action?
Re: adding PCV [Re: mcat4321] #2634601
03/19/19 09:28 PM
03/19/19 09:28 PM
std setup would be a PCV in one valve cover (plumbed to carb base) & a breather in the other valve cover. Not sure which one would be the best (flow amt) for your app & that is new area for me & I'm sure would depend on the cam etc but there is a pic/info of an adjustable one ($$$$$) on page 3 in Q&A. I would Google it also
Re: adding PCV [Re: mcat4321] #2634604
03/19/19 09:34 PM
03/19/19 09:34 PM
AndyF Offline
AndyF  Offline
You'll need to remove one of the breathers and replace it with a PCV. If those breathers mount on tubes then you'll need to fabricate a plug to go in the tube so the PCV has a place to mount. You can use a Ford FE screw in type PCV for a custom application like that.
Re: adding PCV [Re: mcat4321] #2634613
03/19/19 09:46 PM
03/19/19 09:46 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I know what you're getting at because I have the same setup and every time I wash the car I have to wash the engine compartment as there is hints of oil in the dirt. It doesn't just wipe off. Is that a hemi A;body? Sweet!
Re: adding PCV [Re: mcat4321] #2634627
03/19/19 10:31 PM
03/19/19 10:31 PM
Washington
madscientist Offline
Washington
Google ME Wagner and order an adjustable PCV valve from them. Anything else is a waste of time.
Re: adding PCV [Re: mcat4321] #2634635
03/19/19 10:48 PM
03/19/19 10:48 PM
A stock pre 1970 PCV bolt in held with a nut with the stock push on PVC style cap will work fine for your application with the existing K&N breather cap.
All the stock street hemi motors that had chrome valve covers came with chrome PVC caps also scope
Re: adding PCV [Re: madscientist] #2634673
03/20/19 06:32 AM
03/20/19 06:32 AM
PA
Harry's Taxi 2 Offline
PA
so a $5 just won't work.......why not? a little info with your statement might be helpful.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: adding PCV [Re: Harry's Taxi 2] #2634680
03/20/19 07:37 AM
03/20/19 07:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
1969 and earlier street hemi pcv is the path of least resistance. Take one breather off tbe tube, put the pcv in the tube, run the hose as desired. The valve clips into a metal cap which sits inside the tube.
Rich H.
Esse Quam Videri
Re: adding PCV [Re: mcat4321] #2634716
03/20/19 09:20 AM
03/20/19 09:20 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you have a completely stock set-up, then a stock PCV would probably suffice. But if the engine has any mods, then an adjustable PCV has some real benefits. Very few things are 'one size fits all'. That is true for PCVs, too.
http://mewagner.com/?p=444
https://www.powerperformancenews.com/tech/an-adjustable-pcv-valve-for-the-street/
Master, again and still
Re: adding PCV [Re: Harry's Taxi 2] #2634765
03/20/19 11:17 AM
03/20/19 11:17 AM
Washington
Washington
DaveR answered before I saw this, but, like everything else, the PVC system was a serious set of compromises. An adjustable PCV valve is just that. I've used them to clean up dead stock rebuilds and they are worth it every time. Unless you are so cheap it doesn't matter if you can make it better or not.
Re: adding PCV [Re: Harry's Taxi 2] #2634796
03/20/19 12:09 PM
03/20/19 12:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Any cam with perhaps10° or more greater .050" duration than stock has greater exhaust contamination of the chamber at overlap, and reduced idle vacuum.
The amount of air admitted by the PCV is added to the air through the carburetor(s), so it affects your idle's throttle plate position w/r/t spark advance and tip-in response
The Wagner allows you to adjust these factors.
One less thing to worry about? Cheap.
Boffin Emeritus
Re: adding PCV [Re: polyspheric] #2634935
03/20/19 06:52 PM
03/20/19 06:52 PM
Ohio
lockjaw-express Offline
Ohio
If you are running Fuel Injection that has IAC valves, you need an adjustable one...close the throttle plates on your throttle bodies, and then adjust the PCV for half of the idle air needed, and than just barely crack the throttle plates open to get your hot idle for what the FI ECU wants.
My 2 cents...
Re: adding PCV [Re: lockjaw-express] #2634939
03/20/19 07:06 PM
03/20/19 07:06 PM
I ran two stock type PVC with two breather caps on my old Pump Gas Duster motor that had a small solid roller cam in it, 260 degrees at .050 intake side, 266 on the exhaust side ground on a 108 LSA installed at 1 to 2 degrees ICL installed with a stock type low deck six pack set up. Adding the second PVC made it idle a lot better(more air into the intake) and not surge at or under 1000 RPM up
That combination flat rocked, 10.25 ET at 127.+ MPH corked up with the air cleaner on weighing 3450 Lbs. with driver on Oregon 91 octane pump swill boogie devil
